Gents, getting rid of the Suby and getting a R33 Skyline:D . Just got all my audio gear pulled out;
All parts in excellent condition with all orig receipts.
JVC KDSX950 CD head unit, with remote control (RRP $395) - $270
Clarion 170W 16cm Reference 2-way splits (RRP $220) - $150
Clarion Captec V-Net 250 100Wx2 bridgeable amp (RRP $170) - $110
Clarion Captec V-Net 450 100Wx4 bridgeable amp (RRP $389) - $280
Clarion 160mm 150W 3-Way speakers (RRP $145) - $100
Clarion Pro-Audio 500W 30cm USA Sub in black carpeted box (RRP $159 w/out box) - $120
Also have the following, which has never been amplified...
Phillips GTM 1725 16.5cm 2-Way 170W speakers (RRP $140) - $75
Phillips GTM 6295 6x9 2-Way 200W speakers (RRP $210) - $100
Phillips RC438 4x30W tape player/radio (RRP $330) - $150
Phillips 2RRC026/50 6 stacker (which fits head unit) (RRP $400) - $230
Located in Geelong area. Please e-mail [email protected] as this thread may get out of hand:p
https://www.sau.com.au/forums/topic/19198-fs-car-audio-gear/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
