Hi, ive got a full exhaust for an r33 skyline gtst. This set up felt awesome on my car, and the cat and split dump made a real difference as i initially only had the catback
* HKS super dragger cat back system (looks to be 3-3.5 inch piping) the cannon is the oval muffler type. Very nice looking exhuast and is very quiet - $500 FIRM
* 3 inch mild steel Split dump/front pipe from liverpool exhuasts. Very good quality and enables the turbo to spool quicker as it seperates the wastegate gases from the exhuast gases- $275 FIRM
* 4 inch hi flow big metal body cat also from liverpool exhuasts - $275 FIRM
If anyone wants the lot for $950, please take it away
The exuast is on the car atm.
I will take pics in better lighting, but all parts are in good condition.
pick up in Rooty Hill (western sydney). Can post but strictly at buyers expense.
Further info: 0410481565 (Anton)
Cheers
Edited by moonus
Dude you selling your exhaust too??? :rofl:
I personally have heard this exhaust today, and it does sound tough and it isnt loud to attract unwanted attention either.
Win win i say!!
hhaha unlike mine uh anton?? hheheh
haha, hey bro, yeh i think im gonna make turn it all back to stock. ur piece of piping puts out some serious roar. u should start ur own business zorst business dude, hehe.
Mate,
Interested in the cat. Only if its 4 inch though. How old is it?
Ill also need a measurement between the flanges.
Photos would be good too.
Shaun
0414972596
Edited by Shaun
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
