are you running any type of air/fuel control?
if you've upgrades exhaus/cooler then the car is likely to run rich.
cheers guys. Yes, has exhaust, cooler and a few other things. All controlled with an autronic ecu.
Glad to know its running rich, probably will get a few more kw after a tune :D and better fuel economy.
Usually means your exhaust is dirty :D like the guy said black smoke usually ok (especially if it only comes out when u accelerating hard) if its constently coming out you should have it checked, other colour smokes are usually bad.
