which maccas you near bob?
ASPLEY...
I pick up a 2002 Corolla Conquest today so that I can go past without wankers being wankers...
The line is going off the road for a while while I replace some parts, do some polishing and a general tidy up...
Its been a daily for almost 2 years as I sold my n15 SSS to help with spending money for NYC at the start of the year...so it needs a few things!!!
saw a white 33 pulled over in moss street, springwood at around 10am on sunday. feel sorry for you, hope it wasn't too painful.
is autobarn the latest hotspot for the cops?!?!
Im looking for GTR R32 air flow meters if any one knows any one or any where to get them i'm on the gold coast please let me know. And say Hi if you see me driveing its gun metel grey, gold AVS rims, im always in surfer or around that area. Thanks Guys & Girls
OMG that was me!!! (near autobarn right??)
Bastards defected me, bov, pod, steering wheel, boost gauge. Ticked 'major' defect now i gotta get it inspected by queensland transport. :D
Yep that must have been you. Really sorry to hear about the defects. The cops are being real pricks at the moment. We were the silver 32 that drove past you a little slowly, not to gawk, but we didn't want any attention from the cop!
I think next time i go to autobarn i'll take someone elses car. You are the third car in as many months that i've seen pulled over in that area.
Actually i didn't notice you, sorry. The only people i saw drive past were old people with the "cop that you bloody hooligan" expression, like i'd been caught doin 120kph or something <_< (you're not old are ya :lol: )
You needen't have worried, i had the cops full attention, could have pulled a skid right infront of us i reckon.
And yeah, wont be going back to that store anytime soon. Betcha he was waiting round the corner for a 'hot' car to come out of autobarn..
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
