just found out from local residents that driver was speeding down the hill when it started spitting ... of course he would loose all traction ! i hope he wasnt from SAU !.. and his alive
spotted a 33 while test driving my 260 stagea around the logan rd area?? dno bris well at all... sau sticker gota wave
an s1 stag today in eagle farm, an s1 stag goign towards the gold coast, an m35 to the left of the highway coming into bros from sunshine, and a black s2 stag at an import yard... a few oldies on stock s14s to haha...
Silver R34 GTR on redland bay Rd at about 2:45/3:45pm
Then an hour later or so, a R34 GT-T being toyed with by a motorbike, then both flew by.
Hi, you saw.
Silver R34 GTR was me :blink: I see you around a bit... Must be local as well.
Also should mention, my R34 GTR will be up for sale very soon... As well as my R32 GTS-t 4 Door... Contact me for more details ;)
Cheers!
Alicia xx
saw black r34GTT with chromes on the way back from spit last night
plates IR34GT i was in the drift group of s13's. mine was the black one with my username plates on it.
i really wish i braught the 34 out when i saw you. i was like "f**k why am i in my silvia and not my 34"
you looked at me like "pfft.. shit silvia owner" when i own both!
well that was a waste of time if ur not even on this site.
spotted blue R34 on ipswich motorway nrth bound just after the darra on ramp. plates were R34GTT. was cruising behind u up until the granad road exit
:w00t: Spotted you too! :)
Spotted Blue R35 coupe with plates 'FULSIK' Sherwood Rd on Tues. LMAO ;) nice ride :(
Oh, it was you?
I never see the plates for some reason.
Cause i'd definitly know. Same plates still? like your avatar?
Wingless R34 GT-T redland bay rd today.
Yep same plates... Spotted you again yesterday afternoon parked on the side of Redland Bay Road around 5:30pm I guess? No one in the car though... Are you a P Plater? Saw the plates on the car.. Me too! Just too shame to wear mine hehe
spotted grey r33 gtst out the front of the banks/gym @ Northlakes and a white r34 GTT with Gtr wing rolled past @ the same time.
Did that R33 have the plates of "Jethead" or something like that? If so, that guy lives just around the corner from me.
Yeah, i am haha. It is embarrasing, but ah well.
Don't you get pulled over?
white R34 GT-T in Capalaba Central carpark yesterday afternoon
Don't you both drive turbo cars? How can you be P platers and still drive turbo's?
I have a P plate on my front windscreen but nothing on the back, i've been pulled over by the cops and none of them mention it because they just see the one on the front and assume there was one on the back as well lol.
Edited by Tyson 1990
spotted yesterday arvo comming bk from work R34 GTT bayside blue ;) gave u a flash dnt think u saw me was in my 35, you where on mains street kangaroo point ;)
Edited by 53XYN
I got my P's about 4 days before the new laws came in about Turbo's on July 1st 07... No way was I ever to NA! Never have, never will... And don't the new laws of having to display your P plate only apply to P platers after this date also?? I thought so?? I've never had a drama when I have been pulled over... Had my GTR for a year and a half and have never gotten a fine for anything...?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
