Spotted a S1 R33 Gtst on woogaroo st at forest Lake, top half painted green bottom half grey.
Also RBR33 on johnson rd,
plus three other liners within 15 mins coming back to work.
Black 32 on Albany Creek Rd tonight about 8ish turned into one of the housing estates near the bowling alley. Sounded nice!
White 33 at Aspley Mcdonalds plates GTS-R33. Custom plates on an NA? Really? :banana:
Silver 33 Albany Creek Rd waiting at the Gayford St lights on my way back home again.
if you looked at the car you would have seen its a turbo, stealth mate, and GTS R33 looks way better on plates than GTST R33.
Was on the other side of the fence. And custom plates on Skylines never look stealth :banana: I probably would have gone for GTST33.
Was on the other side of the fence. And custom plates on Skylines never look stealth :P I probably would have gone for GTST33.
Speaking of which I've still got '33-GTS' plates kicking around :D Just waiting for a decent offer!
Edited by 666DAN
Saw 32 TUFF black i think abt 9:25am today on ippy motorway outbound, blonde girl, not sure if ur on here, i was going to wave to you but i thought you might of gotten the wrong idea if i did. sorry but :) there we go hehe. (i was the black 33)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
