Spotted a S1 R33 Gtst on woogaroo st at forest Lake, top half painted green bottom half grey.
Also RBR33 on johnson rd,
plus three other liners within 15 mins coming back to work.
Black 32 on Albany Creek Rd tonight about 8ish turned into one of the housing estates near the bowling alley. Sounded nice!
White 33 at Aspley Mcdonalds plates GTS-R33. Custom plates on an NA? Really? :banana:
Silver 33 Albany Creek Rd waiting at the Gayford St lights on my way back home again.
if you looked at the car you would have seen its a turbo, stealth mate, and GTS R33 looks way better on plates than GTST R33.
Was on the other side of the fence. And custom plates on Skylines never look stealth :banana: I probably would have gone for GTST33.
Was on the other side of the fence. And custom plates on Skylines never look stealth :P I probably would have gone for GTST33.
Speaking of which I've still got '33-GTS' plates kicking around :D Just waiting for a decent offer!
Edited by 666DAN
Saw 32 TUFF black i think abt 9:25am today on ippy motorway outbound, blonde girl, not sure if ur on here, i was going to wave to you but i thought you might of gotten the wrong idea if i did. sorry but :) there we go hehe. (i was the black 33)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
