  • Replies 40
Two Uniteds that I know of -
Corner of Goodwood and Crossroad
And there's another up in blackwood.
The Liberty fuel appears to be an E10 fuel also.
http://www.libertyoil.com.au/www/230/10011...le/1001366.html
So no doubt should offer the same advantages. I might check out the local liberty; if they have the E10 I might look at getting the car tuned on it. There isn't a United close enough. :P
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3458598
Yeah i'm at Payneham and the closest United is on Prospect Rd which is about 10-15mins away. Imagine my frustation when i found out they were completely sold out of Boost 98 when i got there!
Premium Max wasn't cheap though, $1.33 p/L on a Mon evening, never seen Boost 98 go more then $1.30.
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3458654
the liberty site is fairly unhelpful in trying to find out about the petrol they sell. they dont really have any information or links about the premium max stuff.
let us know how it goes.
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3458668
I know, i reckon the website is right though. In which case the price wasn't very cheap at all. Not expecting any wonders, Boost 98 didn't do much economy wise.
hmm.
well according to the site both the unleaded 94 and premiumax 98 are E10.
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3458762
I put some of the Shell Ferrari tested fuel (VMax?) and my R34 pinged its ring off the 1st time I booted it. Siphoned it out and went straight back to reliable Mobil 8000 or BP Ultimate
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3459018
hi all,
i've been using Vpower eversince i got my car, and seems ok. never tried bp ultimate. my car is pretty much stock and wondering wether these diffeent fuel make any differences.... i just want my car to be safe... i hear someone's car was pinging while using Vpower? that's a worrie.,.. i might have to try BP ultimate although bp fuel seem to be more expensive...
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3459396
you cant always blame the fuel because your car pinged you have to try and factor in all the invariables
my car occasionally pings but I'm running 12.5-13 psi on a stock ECU
when it pings the weather is normally a bit warmer too
https://www.sau.com.au/forums/topic/192442-liberty-petrol/#findComment-3459469
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
