you cant always blame the fuel because your car pinged you have to try and factor in all the invariables
my car occasionally pings but I'm running 12.5-13 psi on a stock ECU
when it pings the weather is normally a bit warmer too
Due to price of this fuel i think i'd be better off with BP too... i've got the bp mastercard as well so it's worth it.
  • Replies 40
I've always used the Shell premium / Vpower, no worries. BP's in my area are always up at least 5c more on Ultimate compared to Vpower at Shell across the other side of my suburb!
Edited by MSPEC33
Your prob wasting that 5c per litre saving driving "over to the other side of your suburb"
Ive only ever used Ultimate, thats what my car is tuned on so thats what i run!!!
i have always used BP ultimate and never had a problem with it....i have tried the shell Vpower for a while and the BP ultimate for me last longer then the Vpower and there isnt a huge difference but just because there is a BP near me i use the ultimate.....
the 94 product is just unleaded (91 RON) + ethanol = 94 RON
the 98 product is just premium unleaded (95 RON) + ethanol = 98 RON
if they added ethanol to 98 you get 100 RON or thereabouts
the ethanol adds 2-4 RON
regards
Jason
Yeah Deluxe, and my car was tuned on cat piss. I better stop going to shell hey.
Are you seriously that uptight about your fuel?
Edited by MSPEC33
There is a very good reason to be uptight about fuel used.
If the car is tuned for regular 98ron fuel and you go dropping an ethenol blend in it the car will lean out; egt's will raise, the motor will possibly ping/detonate or throw that ceramic turbine wheel.
I have had the odd tank of Mobil 98 that has shown higher levels of det when the car was previously tuned much closer to the det threshold. Dangerman4 actually saw less det with shell vpower.
For a car that is tuned right to the edge it is I think a wise idea to stick to a given brand of petrol.
im always gonna use BP Ultimate
when i first got the car i was using BP, then a couple of months later went to Shell V-Power, i lost 7 kW by using V-power, so i went straight back to BP ultimate, the car wasnt too happy for the first couple of tank fulls, but sorted itself out, and now i wont use anything else but BP. the car is now tuned on it + Justice Brothers Octane Booster
f**k oath im the same, only ever run the one fuel that being ultimate, i will keep driving until i find a bp
i drive from mclaren vale to christies beach to get bp :thumbsup:
bipass the shell in mclaren vale and liberty on victor/south road to get there
Nah not at all, Have paid upto $1.46 for premium the other week! But what you said is like finding $5 in your bedroom and going "sweet i'm gonna go drive to the servo and put $5 petrol in and drive home" Pointless........
But yeh as Joel says, its what your car is tuned on is whats best for it, But a regularly used servo is also the key, the fresher the fuel the better for it, besides the cops use Mobil, so thats outa the question.... :)
interesting points!
Lucky for me, my motor has never suffered pinging or detonation. I've filled my car up with several types of premium except for liberty's/united's.
I have had my 33 for 6 years though... So call me experimental; i've been lucky to never cop a bad dose of premium juice, whether it be Shell, Caltex, Mobil or BP.
will take these suggestions into consideration! :worship:
MSPEC33,
Within the 6years and 180,000km's of owning mine I've only ever had one noticeably bad batch of fuel; happened to be Mobil 8000.
Pinging was audible; similiar as to how it ran with 95ron so at a guess I suspect they dropped the wrong fuel in to the incorrect tank.
At the time the car was still on the stock ecu and running 1bar.
moderate mods sinista, nothing too mental.
yeah i remember that fuel Cubes, was the purple pump with the 'Synergy' label wasnt it?
before BP ultimate was widely available like today with all the 'on the run' servos, it was actually the Mobil 'synergy' premium that a lot of people reccommended!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
