Hey everyone,
I just got a new canon 400DSLR Camara and just finished reading the book and now know how to use it, I'm picking up the tripod on thursday night, so i will be ready for this weekend.
All photos will be posted up on SAU, so all welcome.
I have already spoken to a few other 34 & 33 drivers not on SAU and are keen to come.
(Good chance to make new members.)
I know of a really nice spot we can go to make the photos look GOOD just off the M1.
So if you have nothing to do ths weekend just type ya name and what kind of SKYLINE you have, so i know how many are coming.
Meeting Point: OLD IKEA Springwood
Time: 10:00am (10/11/2007)
Departing: 10:30
Bring: Water, UHF and clean car.
P.S: If its raining!!! its all over!!!
Thanks
Llynden
Edited by Hotr34
https://www.sau.com.au/forums/topic/192580-10112007-photos/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
