G'day all,
Thanks for the 'votes' for my car. I wouldn't say my car is a typical Autosalon car but I guess it has a few of the major areas covered.
Andrew (nuttsHunglow),
I've never had my car in a full feature in a national publication. If you, and more importantly your editors think that my R33 is of the required standard (and is what you're looking for) I would be honoured to have it in a magazine.
It sure looks clean under the hood Matt........very nice ride.
Who did the mods on it?
  • Replies 97
see to the left hand side of the radiator there is a decal :D;) starts with B ends with X
Thanks Steve, I must need glasses.
I'm wondering if Shaun at BW only had a small role in the mods or whether he did the lot......sticker tells me maybe the latter.
Shame he hasn't got a 4WD dyno because he's only up the road from me.
He tuned andys R34gtr and ryans R32gtr with very nice results
I think Shaun or Troy did most or if not all of the fabrication work, but most of the bling bolt on stuff would have been done by himself i think/would have thought!!
not wrong about the 4WD dyno bit and a bigger more open premises on dyno days gets a little fumed out for my liking
I think Shaun said his lease was running up in a year i think, so i believe he might be looking for bigger premisis!! He is always flat out and needs the room for sure!!
G'day Pete, thanks. Yeah as the boys have said the majority of the work has been carried out by Shaun and Troy @ Boostworx, with a reasonable amount of time and effort put in by yours truly.
Hey all
I am sorry that I have not responded or stayed on top of this thread but I have been busy not just with the volume of email but also personal things. I am slowly going through the PM’s and I promise I will get to you shortly.
Andrew
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
