How do these stack up against Genuine Nissan bearings when it comes to reliability with a turbo'd RB...
I was looking through an excel sheet I have of prices of rebuilds etc and I remember City Dismantlers Supply and Rebuild a RB30E Short Motor with gaskets etc for $770. They use ACL bearings.
https://www.sau.com.au/forums/topic/19290-acl-bearings/
oh.. I found some thing for you 93RPS13...
Adelaide Jap Imports - 08 83691945
I think AUS country code is +61
They ship stuff overseas..
Anyway the short block ....
City Dismantlers find a decent RB30E short motor with good clearances then rebuild it with the standard Pistons. They do all bearings, hone, hot tub etc... Then gaskets.. It comes with a sump gasket.
Obviously they don't supply waterpump thermostat etc they do supply the standard RB30E oil pump that if you buy it you have to change to the RB25DET or RB20DET pump...
I thought that was a pretty good damn price and thats assembled.
I hada quick look around last night and a hell of a lot of 500kw RB30's even a RB30DET use ACL bearings with ARGO bolts.. I've never heard of ARGO bolts but they must be decent.
https://www.sau.com.au/forums/topic/19290-acl-bearings/#findComment-405851
Same place they have diff phone numbers.
That City Dismantler info is interesting, do they use new pistons when they do it, what do you think the stock N/a pistons would be good for HP wise. We do a bit of work for city dismatlers truck side so it wouldnt cost me anything.
https://www.sau.com.au/forums/topic/19290-acl-bearings/#findComment-405925
Sydneykid built an RB30DET a couple of years ago that has been making 260rwkw using a GCG turbo. That was using dead stock internals, chipped ecu, 550cc injectors, stock original pistons from the previous life of the engine, and has done 50,000km's with only regular servicing.
Apparently, the power curve was very linier and did not really feel like a turbo car at all. Which to me equals good traction or should I say controllable traction.
City Dismantlers use the old pistons for that price. New Nissan Pistons are $720.. Ouch.. May as well go for the Forged items for that price.
raaaaaaaaa I am supposed to be studying for Accounting and Psyc. I'd better turn off my email proggy for a while and just let Emule Download.. :D
ARIAS pistons are $1600 with rings. Apparently, the ARIAS pistons have better thermal expansion characteristics compared to other forged pistons so they are the better ones to get.
https://www.sau.com.au/forums/topic/19290-acl-bearings/#findComment-405933
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
