Hi there I was wondering if you peeps could give me some helpful answers.
I just got my X-FORCE dump pipes today, spent pritty much all day getting to the turbos and taking them off to mount on the new dumps, but I’ve come across a problem. The dump pipe is touching the turbo inlet piping on turbo no.2, I was thinking at high temperatures would the inlet melt? I have tried to move the turbo as much as I could away from it but still pritty close, its still giving me a 1-2mm clearance. what’s my way around this?
thanks..
https://www.sau.com.au/forums/topic/192959-dump-problem/
Mate maybe speak to the people that sold you the dumps see what they say.I think it should have more
clearance than that.A option rap the dumps in heat rap tape this will avoid burning any thing, they will glow
red hot after a few laps around a track.One thing I have found is that nothing is a bolt on fit you always
have to mod it to fit properly.Good luck
https://www.sau.com.au/forums/topic/192959-dump-problem/#findComment-3465296
When i got my X force 3.5 inch system i had it installed by a reputable installer and the dumps and front pipe where not correctly made to measure, as in it was only 1 or 3mm away from the chassis rails and i would hit for sure. Also where the dumps bolt to the turbos because of the tight tolerances when trying to bolt the exhaust on there was alot of pressure on them which would mean with the bumps etc the gaskets would eventually leak gas out, everything was just to tight a fit. So they just cut and angled the front pipe a little to clear away from the chassis rails and that in turn made alot less tension on the exhaust system. Shit you dont want a flange leak its hard enough to do a exhaust dump pipe change as it is, that was the only problem i came across, i even rang up X force and they wouldnt agree but DID not disagree, i was easy to see, did that and have never had a problem with it and i have had it on now for 8 months and drag raced the crap out of my gtr and its still perfect with plenty of clearance.
https://www.sau.com.au/forums/topic/192959-dump-problem/#findComment-3469692
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
