I have two questions:
1. What do Oil Catch Cans do (other than looking pretty under the bonnet)?
2. Where/how does it connect?
These questions might sound a bit basic, forgive me for that, never looked into it ;)
Thanks in advance.
Edited by WhitePrincess
https://www.sau.com.au/forums/topic/192979-oil-catch-can/
Well I installed my catch can for 2 reasons. Firstly I have an aftermarket turbo, which I run more boost than standard, and a custom intake which I have not plumbed the cam cover breathers into because - I have seen that from time to time for a variety of reasons my engine has had a bit of "blow by" and as a result vapourised oil from the crank case has passed into the intake and turbo and collected in my intercooler and some has gone back into the engine. Over a period of time the oil will eventually build up in the intercooler and you will have to pull it off to drain it and also there will bit an amount of performance loss etc. The catch can collects this vapourised oil instead of it being deposited into the intercooler etc. There are a few threads on how to hook them up on here too. If you need a photo and explanation of how I have mine just pm me.
Hope this helps you!
Smitty
PS. Secondly mine Cusco one looks all pretty cos its polished.
Edited by SmittyR33
https://www.sau.com.au/forums/topic/192979-oil-catch-can/#findComment-3465489
lol did u look @ the other posts open on this?? i did post a couple of pics of where i was going to put it however, i have mounted the bracket above the turbo:S
the position is not a problem, just wanted to know where to connect the hoses... i have seen a few engine bay pics and there are a few different ways ppl connect it
https://www.sau.com.au/forums/topic/192979-oil-catch-can/#findComment-3470973
yeaha i plan to connect mine between the passanger side rocker cover and the intake think this will give the best results, depends or ur engine set up i suppose. hame
can u make a photo once done, or draw on the photo, either way would be helpful.
thanks
https://www.sau.com.au/forums/topic/192979-oil-catch-can/#findComment-3472005
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
