Model: 1997 R33 GTS-t (Series II)
Milage: 70,XXXkm on odometer
Colour: Sonic Silver
Currently registered? NSW rego till November 2008
Price: reduced to $21,000
Contact: PM or call 0402 33 77 27 (leave a message if I don't answer and I'll call back as soon as possible)
Engine:
Garrett GT3040R ball bearing turbo (0.70 A/R Compressor housing, 0.82 A/R Exhaust housing)
Braided Oil/Water lines to/from Turbo
40mm Turbonetics External Wastegate
HKS low mount cast exhaust manifold
Apexi Power Intake with HP coated intake pipe
Turbosmart Dual-port BOV
Nismo 550cc Injectors
Walbro 255l/min intank Fuel Pump
Z32 80mm Air Flow Meter
Jim Berry 'Full Monty' Carbotic Single plate clutch with 3600lbs pressure plate
Blitz LM Spec Front Mount Intercooler
GReddy Oil / Air Separator
Custom made 3" mandrel bend dump pipe and external wastgate adapter (Castle Hill Exhaust)
Custom made 3" mandrel bend exhaust from dump pipe (Castle Hill Exhaust)
Catco 3" highflow catalytic converter with polished Apexi rear muffler
Splitfire ignition coil packs
Custom radiator air guide
Engine Management/Electronics:
Apexi Power FC Programmable ECU
Apexi Power FC Hand Controller
GReddy Profec B Spec II Electronic Boost Controller
Suspension/Brakes:
Apexi Front Strut Brace
Ferodo DS2500 Brake Pads
Exterior:
Nismo 400R Side Skirts
17" P&W Tracer Shadow Chrome Rims w/ polished lip (8" Front, 9" Rear)
Federal SS595 tyres - 75% tread remaining (235/40/17 Front, 255/35/17 Rear)
Interior:
Brant Nemesis alarm/immobiliser (Aust standard)
Nismo 300km/h dash cluster
Trust GREX Chrome Gear Knob
Window Tints - 30%
Custom Skyline car mats
Custom Leather Gear & Handbrake boots
Audio:
Alpine CD/MP3 Audio Headunit
Boston Acoustic Splits - Front
Boston Acoustic 5" speakers - Rear
Rockford Fosgate 12" subwoofer (boxed)
Rockford Fosgate 4 channel amplifier
Alpine 2 channel amplifier
Performance:
Dyno:
286.4rwkw - MRC Performance, Castle Hill
286.6 rwkw - Unique Autosports, Seven Hills
1/4 mile:
11.9 118mph - Western Sydney International Dragway
Car is serviced without fail every 5,000 kms with full synthetic oil and K&N high quality oil filter. All other fluids replaced every 10,000kms, timing belt has also been replaced. I wash and maintain the car very regularly and it's always garaged when not in use.
Nothing has been left to chance on this car. I bought the car stock standard (aside from cat back exhaust) nearly 4 years ago and have purposely selected and overseen all modifications made to this vehicle. All modifications have been carried out by MRC Performance, Castle Hill using the highest quality components and parts. If something wore out or I thought it needed replacing, I replaced it with the best.
I'm a mature, enthusiast owner who has maintained and treated this car with the respect it deserves. The car has been tastefully modified to ensure it remains extremely streetable, yet moderately powerful. It's never been thrashed on the street (in fact, I've never received a speeding fine in this car), although has the potential to be a big performer on the track as evidenced by the 11.9 1/4 mile time achieved at WSID.
This car will not dissapoint. You could not build a car of this quality for the price I'm asking and you'll go far to find another example in such good condition.
Please call or PM me to arrange an inspection - test pilots need not apply and test drives will only be offered to serious buyers.
https://www.sau.com.au/forums/topic/193064-97-r33-gts-t-series-ii-sydney/
Thanks mate :)
I'll be giving the car it's usual 5,000 km oil and filter change tomorrow morn.
Car is ready for the right buyer - 12 months rego, serviced, nothing more to spend and you get yourself a clean, straight 11 sec streeter
Price reduced to $21,500
I've spent well over this amount in mods and tuning, let alone the value of the car itself. This car is good value for the money - it's straight, reliable, has a tonne of power and doesn't attract unwanted attention. It won't dissapoint :P
32psi geez I would hope u have ur internals done.
Where did you get 32psi from??? :)
Car is tuned on 17psi (as you'd clearly see if you looked at the dyno sheet) which is quite safe on a RB25det.
The top line on the dyno graph (solid red) is the power curve - i.e the primary Y axis (left side) = 286rwkw
The lower line (dotted red) is the boost curve - i.e the secondary Y axis (right side) = 17psi
Cheers Tommo :wave:
I should have another car on the way shortly, so would love to clear out some space in the garage. If anyone is interested, give me a call and make me a reasonable offer. You never know your luck, the worst thing I can say is no...
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
