  • Replies 116
yeah i maybe up for 1! specially now that the weather is getting nice! and nights warmer...
but will be working til 5pm so if i can make it i wil(if i dont have any thing else on, i will check with my boss)
Maybe around 7ish? What people think? or even bit later, say 8-9
Need ideas, never really organized a cruise myself, most ones ive been on have left about 9pm, but some always say thats too late..
yeah ill be up for it :) still yet to meet u guys as of yet your cruisses always seem to be on a sat night when i work :P let me know some details and i hope u guys dont mind a 4 door 33 on ya cruise ... im a lil shy tho as i dunno weather my car is up for it as i only have abot 200 rwkw.
lol only 200kw, thats plenty of power mate, cruises we go on dont tend to be races anyway.
I shall be there of course, probly driving the citrus skyline as its been referred to of late lol.
See you all there.
ah~~ might have to miss out on this one as i'm working friday night..... would be good if it was during the day though~~ i think most of people are working during the day i guess..
anyway~ have a fun boys & girls~!!!
cruise would be good as i havent driven my car for about 2 MONTHS!!
got ur car fixed?
yeh had mine off the rd for a year.... you get used to it
need a ride sexy?
or r u taking out the t-rex
wheres this cruise going too? should do a beach cruise 1 day.. jst before sunset or somethin?
why ask? you never turn up anyway :)
Nah andy im off goin rock climbing abseiling and sea kyaking for 6 days starting in about an hour lol so get back next tues then on thurs im off to syd for evo time. Thanks any mate if i was here you know id be there wit you.
Well if it's a 9:00pm meet I should be able to make it. Any earlier, and I doubt I would be there.
Im having a Garage sale on Saturday (from 8am) so need to set that up when I get home from work friday night as to hell with getting up at 6am to setup LOL
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
