still have the xenon headlights, high beam driving lights, standard front bar, front bar reo and rear bar :bunny: send me an offer :rant:
remember, located in newcastle! :D
what colour is the front bar i'm guessing yellow but hoping white? the pics aren't working
  • Replies 70
its actually sonic silver mate :geek:
Do you have the driver's control panel that is on the inside of the door for the mirrors & windows?
sorry man no interior parts, just whats listed
  • 1 month later...
- Genuine Stagea S2 Front Bar (modified for FMIC) - $150 + Postage
--- http://img441.imageshack.us/img441/9741/img5373va0.jpg
--- http://img149.imageshack.us/img149/6703/img5375az0.jpg
--- http://img206.imageshack.us/img206/8286/img5376zu7.jpg
Hi,
Still for sale?
Can you post to Qld, 4210?
Thanks
  • 4 weeks later...
Talk about cheap working G/c xenon's and high beams!
Keen on them bars still, Also got a friend coming down next week!
Would you drop off in newcastle at her son house? I'll Direct Deposit cash first.
