now i have no clue where the otha thread wen,t well i think i no but o well,start another one!!! ;)
excellent night fellas!!!
Fineline
Lazy Bastard
FYN 32
si
shanef
tradeitomeour
lunnatik
sorry if i missed some1
like warwrick said through the night the food was on par with the music :( lol but going for a drive and takin piccys made up for that
Sooo whens pancake manor???? :rofl:
https://www.sau.com.au/forums/topic/194034-westside-chat/
  • Replies 147
He had a bit of a spray about the other thread too. Both are now gone. Seems the Westside thread was rolled in with all the others then deleted for the convenience of the mods.
Sorry couldn't make it, but I was buggered. The jobs on the GTR are almost finished though.
https://www.sau.com.au/forums/topic/194034-westside-chat/#findComment-3480234
Soorrite Goofrey, we didnt missya. ;)
https://www.sau.com.au/forums/topic/194034-westside-chat/#findComment-3480240
deleting threads isnt gonna solve anything, just gunna make people unhappy, besides this thread doesnt need to be moderated because we are all sensible people. The westsiders werent the ones declaring turf wars hahah, geez if its sucha hard task to moderate than dont moderate thats real simple lol
Shouldn't the Sunny Coast thread be deleted as well for consistency?...............
was thinking that too!!!
but anyway keep the pics comin lazy!!!
https://www.sau.com.au/forums/topic/194034-westside-chat/#findComment-3480269
I did!?!?!? was it my plates? cause if so.... wtf is my mechanic doing.
Edit: I suppose he could be driving it around to check one of the things. The main reason it's there isn't something it needs to be driven for.
Edited by ToMMaH
https://www.sau.com.au/forums/topic/194034-westside-chat/#findComment-3480458
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
