I have a voucher for 1 set of ISC coilovers ($1400)
I will sell the voucher for $1350 $1300 $1200. So saving yourself $200 on ISC coilovers.
Specs are as follows:
32 Step Damper Adjustable
* Precise control damp valve
* Operates smoothly on all road surfaces
* Expansion/Suppression of shock adjustment
Pillowball Uppermount
* Adjustable camber allows more/less on road track for all conditions
Piston Rod Design
* High rigidity steel piston rods
* Meets with race/sport standards
Sports Spring
* Made from high quality SAE9254 steel
* Tested over 500,000 times on compression inspection with less than 5% deformation.
Ride Height Adjustable
* Full length height adjustable
* Bound adjustable with separate spring locks
* High quality T6061 aluminium alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminium Bracket
* Made from T6061 aluminium alloy by organic shaping to lighten weight and increase handling performance
* Specifically anodised surface to prevent inside corrosion and surface rust
* On various models camber can also be adjusted via the bracket aswell as the camber tops
Single Cylinder Design
* Larger cylinder and piston design to advance driving stability and dexterity
Edited by JiN_MaN
https://www.sau.com.au/forums/topic/194042-brand-new-isc-coilovers-1200/
  • 3 weeks later...
  • 3 weeks later...
