hey andy
ill have my car in the sau show and shine
be good to meet you on the day for a chat about what will be involved :)
if you could do it, even better!
haha
-mark
Hi Mark I will see what I can do but the limitation at the moment is the time difference between Russia and Oz. 3pm is about the earliest in the day I can cross paths with Russia to get the install key.
Cheers
Andy
Cheers
Andy
you can obtain a key the day before?
good work Tiger!
and I wish... was going to look more seriously next year however those that consider themselves Management decided to drop a bombshell yesterday... rumours for some time but know they will line their pockets with our money.
good work Tiger!
follow your signature...."if in doubt, go flat out"
one more good news, previously my compass heading was off by about 90 degree.
e.g. i'm heading south but my compass on the screen shows i'm heading west.
Chris told me that the further south of the equator i am, the bigger the issue could be as the gyro was configured for northern hemisphere.
after the english conversion applied, not only it fixed my screen's clock to match melbourne's time, it also fix my compass heading!
now i know where i'm heading if i decided not to use the garmin nav.
I think the developer has done more than just translating the language, good work!
in summary:
- japanese translated to english, most screens including some navigation menus, of course the map wont work
- fuel consumption from km/ltr to ltr/100km the australian way!
- clock display showing australian time
- fixed my compass - i can't confirm this until I see other people's compass that was off and is fixed too after to this conversion.
still a skyline, but yeah $6k turnkey solution on V36 I was told - a swap with 370Z ADM unit.
that may sound steep but anyone who spent $45k+ on a V36 might as well get the navi/tv dept sort out properly if there is an equivalent ADM edition available as a donor part.
in summary:
Ok I had a chat with the developer and just to re-cap some of that above to eliminate any misunderstanding:
- japanese translated to english - YES
- fuel consumption from km/ltr to ltr/100km - YES
- clock display showing Australian time - YES
- fixed my compass - NO - my compass was never 'broken' in the first place, here is what the developer said:
The compass wasn't part of the conversion. The developer said I must have had my car's japanese navigation set to a certain destination in Japan by the previous owner and was somehow set to 'align' with some kind of landmark. That skew the compass off as it will try to align the car to a certain point.
When the conversion is installed it somehow either 'reset' that when I removed the japanese navi dvd to insert the install ROM, or either I have now understand what the japanese navi menu means and was able to turn off that annoying destination that the car kept wanting me to go to in the past year or so.
So if you didn't reset it... you could have gone straight to the previous owner's home?
Cool
:D
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
