Can someone please point me in the direction to find a wiring diagram so I may hook up an Australian Sat Nav through the Aux input in the Jap Tuner ? I know I've seen it but can't find it even with a search...
You need to get the Input cable that gives you the 3 RCA plugs. Chris Rogers sells these locally or IM if you want to wait and not much difference in price by the time you pay freight.
This plugs into the OEM TV tuner which in the V35 I believe is under the floor in the boot on the passenger side.
So are you fitting a remote GPS that sits some where out of the way and will be controlled by remote and show on your AUX setting?
Cheers
Andy
Thats what I would like to do thanks Andy , I have a few mates who install car audio and alarms that owe me a couple of favours so I am trying to track down a wiring diagram so they are able to have a look , You wouldn't have a wiring diagram or instructions you could post up for me ?
all the wiring in my car wasn't done by myself - I know the concept although I never tried to find a +12ve wire before - u should not trust me with wiring in your car.
best if u take it to an audio shop.
i'm sure chris rogers said already garmin is not diy. u could end up in tears if u get it wrong.
where did you get your one done?
probably easier to swap the box out.
Hi Chris sorry been away for work and just saw your reply. Picking up my 350GT-8 on sunday. When you say swap the box out you mean remove it and send it to you guys to reprogram for me? sounds like a mission! Surely it would make sens for someone in NZ to have the ability to do cars in NZ. How do I get a disc/license? REALLY need this. help is appreciated.
Thanks for the PM chris but i cant reply only 4 posts need 10!, can you fix that:)
Otherwise i am in christchurch. do you wnat to deal with a car dealer or audio installer?? I can reccomend an audio installer who worked on my honda..
Hi Fraser
It was my PM, Not Chris, any way. I don't really mind but yes, you are probably right. An Audio installer would be good.
If you could send me some contact details that would be great.
Cheers
Andy
Hi Fraser
Cheers
Andy
Auto Sound and Security. http://www.autosound.co.nz/ when you call talk to Pat the owner. If you say the guy (Fraser) with the silver honda integra they did audio and alarm for years ago reccomended him. I went in recently too to get a new sub, should remember me.
Hopefully hes keen!
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
    • Haha good old Letterkenny! If you're looking for another great english canadian comedy, I strongly recommend Trailer Park Boys.
