Can someone please point me in the direction to find a wiring diagram so I may hook up an Australian Sat Nav through the Aux input in the Jap Tuner ? I know I've seen it but can't find it even with a search...
You need to get the Input cable that gives you the 3 RCA plugs. Chris Rogers sells these locally or IM if you want to wait and not much difference in price by the time you pay freight.
This plugs into the OEM TV tuner which in the V35 I believe is under the floor in the boot on the passenger side.
So are you fitting a remote GPS that sits some where out of the way and will be controlled by remote and show on your AUX setting?
Cheers
Andy
Thats what I would like to do thanks Andy , I have a few mates who install car audio and alarms that owe me a couple of favours so I am trying to track down a wiring diagram so they are able to have a look , You wouldn't have a wiring diagram or instructions you could post up for me ?
all the wiring in my car wasn't done by myself - I know the concept although I never tried to find a +12ve wire before - u should not trust me with wiring in your car.
best if u take it to an audio shop.
i'm sure chris rogers said already garmin is not diy. u could end up in tears if u get it wrong.
where did you get your one done?
probably easier to swap the box out.
Hi Chris sorry been away for work and just saw your reply. Picking up my 350GT-8 on sunday. When you say swap the box out you mean remove it and send it to you guys to reprogram for me? sounds like a mission! Surely it would make sens for someone in NZ to have the ability to do cars in NZ. How do I get a disc/license? REALLY need this. help is appreciated.
Thanks for the PM chris but i cant reply only 4 posts need 10!, can you fix that:)
Otherwise i am in christchurch. do you wnat to deal with a car dealer or audio installer?? I can reccomend an audio installer who worked on my honda..
Hi Fraser
It was my PM, Not Chris, any way. I don't really mind but yes, you are probably right. An Audio installer would be good.
If you could send me some contact details that would be great.
Cheers
Andy
Hi Fraser
Cheers
Andy
Auto Sound and Security. http://www.autosound.co.nz/ when you call talk to Pat the owner. If you say the guy (Fraser) with the silver honda integra they did audio and alarm for years ago reccomended him. I went in recently too to get a new sub, should remember me.
Hopefully hes keen!
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
