Thanks for the replies guys,
can anyone tell me though with regards to POD filters - i've been told that the pod filter has to be "separated" from the rest of the engine bay when you take the car over the pits?
Can anyone confirm this?
Thanks
Adam
  • Replies 67
Car was all engineered & given the ok, a bit of drama at the pits over the compressor surge but I won in the end, permits for pod, catch can, front mount & turbo. Says with my details other things like fuel pump & pressure regulator, boost gauge & exhaust aren't required to be added to the permit. With the exhaust part it says it's not required to be added because at the time of testing it was 86db @ 4000rpm, so I'll even have that to show if I get pulled over. Not that I'd get pulled over for the exhaust because those who know my car knows just how quiet it is :D (exhaust-wise...) Took it over with a few factory things to make it easier but what's gone back on there's nothing wrong with it like the rims, only the bov which ideally I'd like to change.
How did they test your exhaust noise?
Curious because if done in accordance with the DOT standard it is very particular about exactly where to measure, surrounding conditions, etc. Be nice to do a check the way the pits do it because I am pretty sure it would be a shortcut method.
Cheers
Cheers
I asked one of the inspectors about that & he got me to put the car in an open space away from everything, revved up to 4000rpm & he measured it with the *insert whatever it's called here*
Then when the engineer came to inspect my car did the same thing at my house & took it out the front to do it, only difference this was from cold start so it was harder to get a regular reading because I couldn't get the revs to stick.
The thing about the surroundings is if you were doing it somewhere with other noise, then that also has to be measured as that could affect it, so if it's done somewhere with no noise it's calibrated to zero & won't give a false reading.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
