Newbie qns: Possible future Skyline owner...
Guest Asterix
Hi all, I'm new here.
I currently own a Mazda Astina, but I've always liked the Skylines.
I am thinking of buying an R33 GTS-T as I prefer the look over the R32, and they are cheaper than an R34.
I have never owned a turbo before - have had mates whose turbos have blown. Wondering how reliable they are & what maintenance is involved. I know it depends on how hard they are driven.
I've just started looking around at these cars. I test drove one. It went OK, but I was a bit concerned with the response on gear changes. It was a 5 spd manual & each time the clutch was depressed & the BOV spewed out, it was almost like the brakes were tapped for a second or so. Not smooth like putting in the clutch of any other car? Is this normal?
What else should one look out for when buying one of these?
I noted the post about dodgy bodykits. That was a good one. Can anyone please send me pics or a URL to the pics.:D
I don't expect much negative comment on these cars from a Skyline forum, just any honest advice from past experience with problems or stuff to watch out for.
Mnay Thanx in advance,
Asterix:D
lol.. speak to dj_lethal - he's in melbourne and went from an Astina to an R33 GTS-T as well ;)
Turbo should not blow unless you wind it well beyond its capabilities. Most cases I hear of turbos being blown is people who don't know what they are doing.
That "hesitation" on gear change, especially with a BOV is perfectly normal. The key is basically to flat shit the sucker :D and bang it in as quickly as possible while keeping the revs high. Ok, maybe thats a bit extreme, but in general you have to be a bit quicker on the clutch/upshift than a n/a car. Depends on the clutch too.. if its a heavy duty clutch then that takes a bit of getting used to as well.
Its probably something that seems strange at first getting used to a turbo, but you soon get used to it and begin to love it. Its very hard to go back then :(
i believe "in-gear" lag will be accentuated with an addition of a externally venting BOV. the reason being that the pressure in the pipes will need to be filled again.
and yes, a turbo car is generally quite reliable these days pending the amount of TLC its had...
Also, should you steer clear of a turbo that's been boosted?  This must apply added stress/war to it.
Yes and no.. In Skylines, and Japanese turbo cars in general, they often over-engineer much of the engine to handle much greater stresses than the stock boost levels and everything else.
That in mind, it can handle quite a few power upgrades, but also they have to have been done intelligently and matched with other appropriate upgrades (an aftermarket intercooler is probably a good idea). If this is the case, then reliability shouldn't be an issue. So therefore look for recognised upgrades/tuning history from established performance workshops, or if much of it was done in Japan generally the quality of workmanship is high.
Expect around $500 + fitting for a (2nd hand) stock turbo fitted if blown.
Guest Asterix
Thanks for the sppedy replies guys!
I also was told that an intercooler is a good idea as it sucks in cold air for the turbo to keep it cool.
Mind you, the salesman also told me that a BOV is detrimental for the turbo & makes it work harder.
My Soarer TT mate says that is buls#$t & that it is better for it.
The main problem with R33's is they are getting a bit old and are starting to get the usual old car problems. That includes worn synchros on the gearbox, timing belt, water pump, brakes, fuel pump, turbo, etc. However the engine itself is quite strong, the engine usually does not leak or burn much oil at all. Test the engine compression and if it's good on all cylinders then you've got an engine good for another 50-100k km (or more).
I have a '95 model that's just clicked over 100 000km (based on the condition of the interior and engine I believe it hasn't been wound back) and the only thing "wrong" with it is it crunches on 2nd gear (and sometimes 5th) when cold. Aside from that it feels like a new car to me.
Losing power between gear changes could mean a badly-adjusted bov or a sticky clutch, I don't experience such power loss on my car (atmo bov).
No maintenance is required on turbos. If yours is in good condition and you treat it properly (using good quality synthetic oils and letting it cool before switching off) then it should last as long as your engine. The big problem is being a second hand car means that the previous owners may have not treated it well.
Firstly, don't EVER listen to a word the salesman has to say. They generally don't know their balls from their moustache, and will say ANYTHING and EVERYTHING to try and get you to buy the car, truth or not.
If you have any questions, ask us here, we'll give you the right answer.
In simple terms, the BOV basically vents the air the turbo is pushing into the engine when you step off the gas. The throttle shuts, and the air usually has nowhere to go except back through the piping and hits the turbo, forcing the turbo to stop, and spin backwards. This is called reversion, and is detrimental to turbocharger's lifespan... The BOV is an outlet for the air to go, so it doesn't go back through the piping and hit the turbo. It's a good thing.
The Intercooler is basically like a radiator for your intake air. Cooler air means denser air, which means more power and less chance of detonation. Again, this is a good thing.
An intercooler won't keep your turbo cool as it's installed after the turbo. An oil cooler would be more useful for keeping your turbo cool, but still it's generally overkill for a street-driven car.
intercooler .. depends what boost ur running .. if u want more power to run high boost .. then i guess a bigger IC would be safer .. but if u just want a normal stock standard car .. then the stock intercooler is fine .. just don't go buying a boost controller and try running 20 psi on stock cooler and turbo ...
also a good thing to look out for is if it has an old turbo timer installed (usually means its been on there for a while and the turbo should be in pretty good condition). Ask to see auction papers, service reciepts.
If the ks are well under 100 000 (ie 70, 80 000) check to see if the timing belt has been changed (look to see if the bolts on the cover have been loosened, like burred) that is usually a good indication that the belt has been changed a 100 000 and they have wound the them back.
like any car, there is always some uncertainty when buying. Skylines seem to have a good reputation for a quality car and aftermarket parts are becoming easily accessable too.
Happy hunting
How can anyone confirm something as general as that, even if they lived in Japan? Maybe they live in a neighbourhood where no one, or everyone services their car properly.
Whether or not my Skyline was serviced properly, the engine is still in better condition after 100 000km than my previous V8 Commodore's (at 80k km), which definitely was serviced properly.
I have not owned a car whose engine was in better condition than my Skyline's, that's all that counts. I could be fed any story as to whether or not the previous owners had treated it properly, but it wouldn't affect the condition of my engine today.
My car gets the full synthetic oil treatment every 5000km and hopefully that will be enough to see it through another 100k km or more.
Yeah just thought it would be something to consider when buying one. I read this in a jap import magazine. The reason they say is that keeping the service history up to scratch on a new car in Japan would make absolutely no difference to the value of the car when the time comes to sell or trade. Cos they wont get much back either way..
Well, if the car is blowing great plumes of smoke at the auction yard it wouldn't even sell, so that's a good incentive at least regular oil changes. Most of the rest of it can be done as a cure rather than a preventative operation - ie, coolant, plugs, brake fluid, etc. The engine oil is the important one, the rest can (generally) be skimped without affecting the car too badly.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
