Make: Nissan
Model: KRPS13 (180sx), minus the K because hicas is locked. :verymad:
Milage: 120,00 on chassis, 20 thousand on new engine.
Transmission: 5 speed manual
Colour: black
RWC supplied? n/a
Currently registered? sure is
Price: 14k-Neg.
Contact: Tim-Via this thread, pm or mobile 0407795149
Comments / Modifications:
time to sell the 180 and get something different.
heres a run down; i bought it stock and have done all the mods myself, apart from the obvious stuff.
1991 180SX-sunroof model
5 speed manual SR20DET
Rebuilt with forged pistons by Chris Milton Engines-receipt included.
Full 3 inch turbo back mandrel bent exhaust with hi flow cat and stainless steel muffler-receipt included-still with warranty
FMIC
Brant AA02A alarm with triple cut, glass break sensor, battery back up siren and 2 remotes-receipt included
Turbotech boost controller-set at 12psi
Rear Tein coilovers. stock struts included.
Locked hicas, with lock bar and all lines and hicas pump removed all the way to the front-done properly, not looped back at the rear of the car, hicas light has been disconnected, but will still come on if power steering level is low. like i said, done properly.
Rear strut brace.
Speco 2 inch boost, oil press and water temp gauges.
turbo timer-not installed
battery box and cables/terminals for battery relocation-not installed.
K&N pod filter
A/m steering wheel.
Kenwood h/u, pioneer 4-way 6 inch speakers in doors, kenwood 6x9s rear.
Rw front bar(black), i hit a rabbit driving home and broke a chunk out of it, so zip tied it back together.
Type x front bar(white)-currently on the car-car will come with both front bars.
Nismo side skirts.
vented headlight cover
now for a few minor problems.
no rear seatbelts. got the buckles, but not belts.
minor scratches, dents around the car, bit of paint fade on the bonnet-all been there since ive had it, nothing that cant be expected of a 15year old car.
speedo is out by 20k. ive got an rsm, so dont use the dash speedo. may include rsm in sale, havent decided yet.
sunroof rattles a bit, but is fixable.
serviced every 5000ks. running royal purple oil and using genuine nissan oil filters. always run on BP ultimate.
it had a dyno tune before the rebuild and made 126kw on stock boost. i have a printout for it. hasnt been tuned since it has been built.
never been on a track or defected or had any other problems. ive owned it for about 2 years and other then over heating once due to blocked raditor it hasnt skipped a beat.
i have a folder full of receipts for everything thats been done to it, from the engine receipt right down to the wire used to wire up the gauges.
it will come with some stock parts, intercooler etc, and a bunch of other stuff, (unused battery box, turbo timer etc)
im sure ive forgotten some stuff, but ill put it up as i remember.
ill put some up to date photos up soon, but all thats changed is the front bar.
Images:
Edited by ted180
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/
should have no trouble selling this, we get inquiries for 180sx's all the time.
difficult to get them at a good price from Japan.
good luck with the sale!
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3487769
couple of things i forgot to mention;
either of the 2 front bars can be resprayed for serious buyer.
and i would like an R32 GTR, so ill accept swaps plus cash your way if you have one that suits me.
to keep this car as legal as possible ive done the following;
removed bov and replaced with stock piping.
removed turbo timer.
moved guages below the dash(legal).
only thing that can it can be defected for is coilovers. but with no bov or turbo timer there is nothing that will draw attention to the car, so getting pulled over isnt a common occurance.
and ive got hardcopy technical manuals.
Edited by ted180
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3489640
the owner of this car treats it like a baby, i can vouch for the fact that its well looked after. never thrashed, regular servicing and maintenance done. only tasteful mods and a nice looking car too! :D
https://www.sau.com.au/forums/topic/194584-sa-krps13-180sx/#findComment-3491801
  • 1 month later...
  • 3 weeks later...
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
