thats so bad that they can just pull you up in another suburb and get you to follow them there, what if you had to be somewhere, i mean fair enough if you drive past and they pull you in, or pull you over on the road and defect you or sumtin. are they allowed to pull you up and just say follow me through a few suburbs so we can look at your car, sounds like harrasment or somthing
  • Replies 55
Sure can. Happed a fair bit last year. Even cars like 4GIVME got done in this way - was seen by other cars in same empty factories and such. I think they had one going off parra rd too.
The one in castle hill was a showground or something. Next to council building. Very dodgey.
thats farked, id be seriously pissed if that happened to me, its just wasting your farkin time, like at least an hour of it if you have to drive somwhere else, then what if your car passes, they've just wasted your time, what if you had somwhere important you had to be.
i heard about a guy today who was getting done by the EPA At brighton he got fined $15,000 Man id be killing myself right about now....
I ended up fitting a standard airbox it wasnt a GTR One but was one were my chrome pipinmg can get into.... went to the guy again at Granville He wouldnt pass it Because there wasnt Air flowing from the top of it through the filter into the turbos... This guy Man i swear is doing my head in..I cant wait until this is all over....
can you go to another guy, and also is this guy an old or young guy just out of curiosity?
probably in his 40s
this guy's own son's commonwhore (what else) was louder than my exhaust.....most of the car in his workshop is louder when they were moving them around....but i had to get mine passed !
he didnt even pass me when i rocked up with a full oem gtr exhaust! i ended up wasting $250 for parts and labour + $100 for him to pass the car with his fees (everytime you get tested you get charged!) and a couple of days off from work
one of the biggest rorts around i reckon....especially when there are only 2 workshops to choose from....this one or the one at Campbelltown.
what if you got smaller piping or anything like that between the turbos and intercooler, that will fit or that you can manage to bend around the stock box, then just find a way to disengage the turbos, so the pipes wont even need to run anything, drive it there and back, and your done.
BTW if you change the box is he gonna make you do another emmisions and noise test??
haha now u understand what i went through, but i got off lucky,
all this drama for a Fcukn Pod!
na na ive already passed the emissions test doesnt matter... I will have to do a noise test again because i am going cambeltown but i will pass beacuse ive put a stock box on now rather then the aluminium one which means less noise corect ?? well i hope so ???
Thats the dillemma i have the guy at granville only have to pass my filter box but the guy is a big d** head so im gona go striaght to cambeltown hopefully i get treated better there...
Edited by MRGTR911
If by "the guy at Campbelltown" you are referring to the Defect Notice Clearance Inspection Station, then i can shed some light for you. To me he appeared quite reasonable and approachable. I had been pulled over on Parramatta Rd and escorted to one of these make shift inspection stations in a industrial factory complex, at which point the examiner was overcome by the quantity of mods before him, Larger turbo's, pods, ebc, cams, cam gears (visible), larger FMIC, ecu, etc, so much so that he generalized the defect to read "all engine mods to comply with relevant ADR's & exhaust noise check".
I took my vehicle to TIC and had it engineered, covered the pods with an aluminium housing (painted black), stuffed a restrictor in the exhaust and generally hid the things i didn't want seen.
Went to the Campbelltown Guy, he took the engineers word for all on the report, no follow-up noise check, no probs with the enclosed pods, passed first go, defect cleared.
BTW every time i'm RBT'd i get asked to pop the bonnet, i produce the Engineers Report, engine bay checks ok, get hassled re noise (have since fitted HKS Silent Hi Power 95db), i assure them it gets quieter with rpm, rev engine to oblige and have thus far been allowed on my way.
Sorry for your pain, it annoyed the hell out of me at the time, i can only imagine what your going through.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
