****need to sell, first in with money can buy...tired of holding parts
As per other thread I am wrecking an R33 gts-t '97 series II White, 70,000km front end damage. All items will be in very good/excellent condition unless stated otherwise, all bolts/nuts etc included with individual parts. Both air bags went off in the crash (front right end smash), all front suspension arms are damaged both sides, the headlights/radiator/front bar/bonnet/front guards/intercooler are all damaged and of no use.
Link to all pics labelled and in here---> http://s127.photobucket.com/albums/p148/PT15/
(if no pic found then you should know what it looks like already)
Items NOT available are the gearbox, diff, front/rear brakes, handbrake.
ENGINE PACKAGE available, motor/ecu/loom/afm/turbo/clutch fan (ie complete) for $2500neg SOLD
Standard clutch cover and organic clutch plate $50
AFTERMARKET PARTS
Razo shift knob $50 http://i127.photobucket.com/albums/p148/PT15/RAZOknob.jpg
Speco boost guage (mechanical with cup holder, silver 52mm, reads to 30psi) $75 http://i127.photobucket.com/albums/p148/PT15/Specoboost.jpg
Greddy M-spec cold pipes for FMIC (only cold side) $30http://i127.photobucket.com/albums/p148/PT...dycoldpipes.jpg
Personal brand 320mm steering wheel (no boss kit)
-complete with horn button (carbon centre), black leather wheel very good condition $75neg
http://i127.photobucket.com/albums/p148/PT...teering0003.jpg
INTERIOR/CABIN PLASTICS
Door skins excellent condition (with clips) $40 each ($65pair) CHEAP
http://i127.photobucket.com/albums/p148/PT...oorinterior.jpg
passenger power window switch $20
Interior cabin carpet (no rips or stains etc) $100
Cluster plastic surround $20
RB25DET clutch fan assembly $80
mmm extra cooling for those hot days bolt on to any SR/CA/RB
http://i127.photobucket.com/albums/p148/PT...33clutchfan.jpg
Plastic door piece (says "SKYLINE") $60pair http://i127.photobucket.com/albums/p148/PT...doorplastic.jpg
Roof lining $50
Sunvisors $30 pair ($20 each) EDIT: $20 the pair as I damaged a clip on passenger side
Rear vision mirror $20
Interior lights both $30 ($20 each)
All interior surround plastics with x3 grab handles $120neg
(ie all of rear + A/B pillars)
http://i127.photobucket.com/albums/p148/PT...Rdoorpanels.jpg
http://i127.photobucket.com/albums/p148/PT...riorrearALL.jpg
SEAT BELTS
http://i127.photobucket.com/albums/p148/PT15/rearseats.jpg
Seat belts with brackets/bolts $180 the lot (or $100 front/$100 rear)
http://i127.photobucket.com/albums/p148/PT...LLseatbelts.jpg
DOORS, DOOR SEALS, LOCKS
Passenger door complete with door seal, windows, power window motors, door handle etc are all included $150
passenger (has a paint chip as in pic) http://i127.photobucket.com/albums/p148/PT15/0024.jpg
driver door $100 (no window motor) http://i127.photobucket.com/albums/p148/PT15/0023.jpg
Rubber seals for door shell L&R $50 ($35 each)
Rubber seal for boot shell $20
Door ajar sensors complete $10 each
if separating door parts:
driver's door handle $35
passenger door handle $30
driver or passenger window $50 each (or $80 pair)
passenger power window motor $50 firm
BODY WORK, TAIL LIGHTS etc
Tail lights with covers/globes/wiring $80each ($120 pair) http://i127.photobucket.com/albums/p148/PT...nish_grille.jpg
Rear centre garnish (says SKYLINE) $50
Weather strips L&R with all clips $50 CHEAP
http://i127.photobucket.com/albums/p148/PT15/windshields.jpg
Rear reo bar (undamaged) $100 http://i127.photobucket.com/albums/p148/PT15/rearreobar.jpg
Side skirts damaged see pics $40 pair http://i127.photobucket.com/albums/p148/PT15/sideskirts.jpg
http://i127.photobucket.com/albums/p148/PT...skirtdamage.jpg
MECHANICAL, SUSPENSION, other
Brake booster & manual brake pedal/bracket $70
Rear sway bar (standard with mounts) $40
Rear camber arms $30 pair (sold as pair)
Rear traction arms $30 pair (sold as pair) (shorter arm near front of wheel arch)
Tie rod boots (front) $20pair
Front ABS sensors complete $30 pair
ELECTRICAL, WIPERS, HORNS, misc
Front wiper motor $20
Wiper stalk $35
Rad and A/C clamps $20 all 4
Horns x2 with wiring $30
Front seats$250 pair (passenger x1 small cigarette burn)
Rear seats $100
Accelerator pedal & throttle cable $50
Simota pod filter with adaptor to suit Z32/RB AFM's
Subframe $100
Clutch Master/Slave cylinder $100
Rear parcel shelf with speaker covers $80
Climate control unit $50
Indicator stalk
Electric aerial $30 (missing black rubber surround piece that seals it to the quarter panel)
Rear wiper $20
Rear water spray nozzle and lines $20
Cluster/odometer (showing 70,036km) $100
Electric mirrors L&R $50 each (or $80 the pair)
Glovebox (minus key lock) $20
Standard grille $30
Rear pods $50 pair
Boot with adjustable spoiler (see pics) $250 complete with gas struts etc (spoiler alone $200)
Rear bar few light scratches (no cracks or dents) $150
Bonnet heat lining (with all clips) $40
driver power window switch $30 sold
Entire boot lining (including floor lining) $100
Clutch pedal/bracket & master/slave cylinders including all lines $100
Nismo rear suspension $300
Space saver $50
Turbosmart Type I BOV with R33 adaptor $100 sold
Gizzmo EBC with manuals/wiring etc sold
Jap cat-back exhaust (appears 3" to 3.5 or 4" haven't measured it) $350
Greddy water spray bottle for R33 $75
Steering wheel (no air bag) $50
Centre console $50
Gearboot surround $50
Stereo surround $50
Dashboard with top vents undamaged (as per pic) $120
'97 R33 gtst (2 door) full matching replacement set of keys/locks, this includes
-gold Nismo key cut to suit plus original Nissan key
-ignition barrel/lock mechanism (complete)
-driver/passenger door locks
-boot lock
-glovebox lock
All in excellent condition
Price: $150 sold
Standard R33 turbo (no shaft play) $450
Stock Manifold $80
All oil/water lines plus banjo fittings $60
Stock dump/front pipes $40
^^^ALL of above $450 SOLD
Engine loom $80
Standard ECU $100
Entire loom from car, uncut one entire piece $80
^^^ALL of above $135 SOLD
RB25DET AFM (no mesh) $100
Rubber intake pipe $30(includes the re-circ pipes etc)
Simota pod filter and RB/Z32 AFM adaptor $30
^^^ALL of above $120 SOLD
STEREO
double DIN both CD and MD player
Factory speakers and mounts front/rear
Factory stereo brackets
$80 the lot
the following is damaged beyond use to anyone and as such has gone to the tip.
-bonnet smashed
-front bar (already gone)
-front reo bar
-Greddy M-spec FMIC kit (only the cold pipes survived)
-elctric fan for air con (fan is OK but the shroud is stuffed)
-headlights both L & R
-front guards both L & R (L is a little damaged at front will give away)
-rad support (centre piece is "ok" though)
-rad shroud
-radiator (only the bottom plastic tank is good)
-tie rods L & R bent
-lower control arms L & R both snapped
-front swaybar links L & R snapped (not sure on the bar itself yet)
-front Nismo shocks: L has a bent shaft, not sure on R (will give away free with sale of rear Nismo shocks)
-castor rods: L is bent, not sure on R, but both have good new looking poly bushes that may be of interest
-windscreen cracked
Edited by PT
  • Replies 116
couple of more items sold
also have heater box $40
boot release lever and cable etc $30
bonnet release cable/lever assembly $30
rear windscreen and L/R quarter windows are also for sale, still on car though
Hey champ, got a mate that is very interested in a turbo. If your willing to split the turbo from the motor let me know via PM. Or if you know of any other turbo's to suit an RB25.
Oh, and with the brake booster i dont think i'll worry as i was kind of looking for a booster and M/C together.
Thanks.
Edited by kitto
hey mate im chasing a driver side power window switch and possibly the motor for the drivers side window??
thanks luke
sorry window switch just been sold
I still have the motor for driver's side though
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
