eh?
why would you go else where....
autobarn sell davis craig...and repco sell recpo which is just the davis craig repackaged.
both are fine you just need to get a controller and sensor...i would recommend pivot.
you want cheap - go to any good auto elec and ask for 'oex' brand, good and cheap, davies craig is mid range and spal are top end.
where you located? OEX make EXCELLENT thermo switches which are cheap too, you after electronic switching or mechanical?
im using ICE thermos hehe... works well and use std R32 sensor/switch on rad
u guys do it all the hard way..
K.I.S.S
ICE thermos are made by OEX :wave: there the ones I was talking about hehe good value for money
thanks for the replies guys.
repco wanted to charge me $240 for a 16" straight blade.
supercheap had calibre 16" straight blade for $100
im on the southside so where is a good place to get these oex or ice thermos from? im looking to switch it electronically.
basically my clutch fan is stuffed and im looking at $140 upwards to replace it so was hoping to fit a 16" thermo in the stock shroud for around that price. less if i can.
ive searched and apparently the s shape blades are better which is why i stayed away from the straight ones i dont want to have issues with heat.
thanks alot
thanks alot
repco sell the ICE ones but put a horrible markup on it, kinda complicated to explain the ICE/Repco relationship though. PM me with your suburb and i'll tell you where to go :D
ICE thermos are made by OEX :) there the ones I was talking about hehe good value for money
yep.. :)
thanks alot
hmm $140. ill supply and fit a GTST hub fan for $60 interested.. :3some:
thermos are for E-W mounted engines.. and RB silvias :D
definatly could be interested. i just want to get rid of the f**king annoying whirring noise that im pretty sure the clutch fan is making.
i thought it might of been beneficial to go a thermo fan because it lessens the drag on the engine (yeah i know it probably makes bugger all difference.)
been reading mixed reports about going to thermos though.
I just installed a Twin thermo setup in a shroud. A bit of trimming and it's a perfect fit on a stock R33 radiator. A bit more trimming for a close fit Ally 50mm radiator. Came from a late falcoon for $200 from Autobarn (or less on trade). Used an in hose fitting for the 90deg on/80deg off thermal switch.
I just have to get the current draw right. It's pulling more than 30 Amps so fitting a new relay and stepping up to a higher fuse rating tomorrow.
I am looking at setting up twin thermo's from an AU in my R33 too, how have they gone in yours so far? have you got any pics of your handy work? was the thermal switch expensive?
K.I.S.S
the over temp switch in the r32 rad come on tooo late (90.c) but if u buy a temp switch of a mitubishi lancer/marage /magna (tridon part no TFS141 for around $30 which is a bolt in replacement and it comes on around 83.c
i use these all the time when i do rb conversions into silvias with 1x14in and 1x12in thermo fans on a r32 rad and never had any over heatin issues
well pm me mate.
may do cheaper.. lol
not much diff in going thermo. ull find it will prob over heat. and ull find that ur batt alternator has more load now. so ur car will load up more to charge. yay
cool thanks man, probably send a pm your way in the next couple of days.
as long as that annoying sound is gone at the end of it i'll be a happy camper
cheers
ohh cheers for that mate. ill keep that in mind. havent had an issue with the RB sil yet. its actually been more reliable than my older cars. ill look into switchin it next time i do one.
yeah, clutch fans are way more efficient at cooling the engine... get marki to check it out he's awsome at wat he does
thanks brenton.
hey u wanna come watch at the strip on wednesday night ill send ya a SMS.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
