Hi everyone, I've also just joined this site and wanted to say hi.
I flew to Sydney a couple of weeks ago and picked up my new toy (R34 GT-R V-Spec) from a dealer then drove it back to Adelaide.
I've purchased a whole bunch of bolt on bits in the meantime (Garrett Turbos, fuel upgrade bits, bigger intercooler, Power FC etc) that I'll be fitting once I get it through inspection.
I'll probably do most of the work myself but I need a good tuner for the Power FC so I'd love to hear everybodys thoughts.
Here are some pics of the car at the dealership before I picked it up.
If you see a grey R34 GT-R with yellow NSW plates while your on the road, come and introduce yourself so I can put faces to the names on this site.
Cheers Pete
https://www.sau.com.au/forums/topic/195075-new-member/
  • Replies 56
Posted Images
Nice mate, how crap is that drive i just did it Fri night...lol andy did the same with his 34 too, where bouts did you get it from, and go see shaun at boostworx for your tune.
It was from a mob called Unique Cars on Paramatta Road. Thanks for the tip about Shaun.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495798
Hi welcome to SAU
have you been in the Pasadena area recently? as i think i have seen you a few time. Car looks really clean
yeh I reckon I have been through there a couple of times. Give us a wave next time you see me.
I sometimes ride a full custom black and silver bike through that area, the 'SLED'.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495806
nice ride mate. Welcome to SAU. Looks like the engine has been out, as the cam cover "RB26" is not normally been painted red from memory.
So it's got an oil cooler, HSK intercooler .... what other bits does it have?
How much did u pick it up for? (if you don't mind me asking). It's amazing how there are so many around for under $60k, yet there are still some dreamers asking up to $100k for them.
Enjoy your new toy :teehee:
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495814
Price wise your not far off the mark. It has got an oil cooler and HKS piping but a standard intercooler (for now).
Motor hasn't been out though, all R34 V-Specs have red covers while the NUR's have silver ones.
It's also got TEIN suspension so its a bit of a hard ride even on the softest setting.
KAKIMOTO dual exhaust from CAT back, but the front half will get a change too pretty soon.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495841
nice ride you have there..... though why mod it, wouldn't it be quick enough as is hahahaha :teehee:
Hi Glen, you're right it is pretty quick at the moment but I'm a bit of a rev head so it's never quick enough unfortunately.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495842
yah...damn long drive, but an enjoyable one :teehee:
Hello SLED
another 34 GTR to SAU-SA
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495855
can my car have your cars babies?
Hi Cara,
I tell you what, you've got a pretty good looking machine yourself so their offspring could look like a baby 2008 R35 GTR.
I think if our cars ever met we would have our hands full trying to pry them apart!!!
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3496372
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
