Hi everyone, I've also just joined this site and wanted to say hi.
I flew to Sydney a couple of weeks ago and picked up my new toy (R34 GT-R V-Spec) from a dealer then drove it back to Adelaide.
I've purchased a whole bunch of bolt on bits in the meantime (Garrett Turbos, fuel upgrade bits, bigger intercooler, Power FC etc) that I'll be fitting once I get it through inspection.
I'll probably do most of the work myself but I need a good tuner for the Power FC so I'd love to hear everybodys thoughts.
Here are some pics of the car at the dealership before I picked it up.
If you see a grey R34 GT-R with yellow NSW plates while your on the road, come and introduce yourself so I can put faces to the names on this site.
Cheers Pete
https://www.sau.com.au/forums/topic/195075-new-member/
  • Replies 56
Posted Images
Nice mate, how crap is that drive i just did it Fri night...lol andy did the same with his 34 too, where bouts did you get it from, and go see shaun at boostworx for your tune.
It was from a mob called Unique Cars on Paramatta Road. Thanks for the tip about Shaun.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495798
Hi welcome to SAU
have you been in the Pasadena area recently? as i think i have seen you a few time. Car looks really clean
yeh I reckon I have been through there a couple of times. Give us a wave next time you see me.
I sometimes ride a full custom black and silver bike through that area, the 'SLED'.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495806
nice ride mate. Welcome to SAU. Looks like the engine has been out, as the cam cover "RB26" is not normally been painted red from memory.
So it's got an oil cooler, HSK intercooler .... what other bits does it have?
How much did u pick it up for? (if you don't mind me asking). It's amazing how there are so many around for under $60k, yet there are still some dreamers asking up to $100k for them.
Enjoy your new toy :teehee:
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495814
Price wise your not far off the mark. It has got an oil cooler and HKS piping but a standard intercooler (for now).
Motor hasn't been out though, all R34 V-Specs have red covers while the NUR's have silver ones.
It's also got TEIN suspension so its a bit of a hard ride even on the softest setting.
KAKIMOTO dual exhaust from CAT back, but the front half will get a change too pretty soon.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495841
nice ride you have there..... though why mod it, wouldn't it be quick enough as is hahahaha :teehee:
Hi Glen, you're right it is pretty quick at the moment but I'm a bit of a rev head so it's never quick enough unfortunately.
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495842
yah...damn long drive, but an enjoyable one :teehee:
Hello SLED
another 34 GTR to SAU-SA
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3495855
can my car have your cars babies?
Hi Cara,
I tell you what, you've got a pretty good looking machine yourself so their offspring could look like a baby 2008 R35 GTR.
I think if our cars ever met we would have our hands full trying to pry them apart!!!
https://www.sau.com.au/forums/topic/195075-new-member/#findComment-3496372
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
