Does anyone know of a tempe tyres equivilant in or near Brisbane? I need to get some cheapish rims and tyres for a Hyundai Getz (don't say it!). I am contemplating going to Sydney to get them from Tempe, but I am wondering if there is anywhere up here? It would also be good to know of somewhere here where I can get cheap tyres when needed.
Any help or pointers would be greatly appreciated!
ozzytyres is probably one of the only "equivalents" but steer clear if your not into shit service and bad cologne.
Jap rims FTW!! check out some of the importers of second hand stuff for sale section always is good place to start!
For a High Undie getz?
tempe tyres is only $80 delivery for a set of rims and tyres.
Also Superior tyres at Aspley
I agree, why drive there when you can get them sent up for $80
Superior, Ha, now thats funny.....used them a few years ago when that moron Kel owned it and swore I'd never return after shocking service and after being told I'd be getting 6 months interest free on my AGC purchase, they never ticked an interest free box and I was charged interest from day one....they never bothered to rectify the issue after many, many phone cals and visits! Then I went back early this year after I was told they were new owners, got ripped again, was supposed to get Hankooks on my 22s and they gave me Nangkangs, then tried to tell me that I got the better tyre in the Nangkangs, and wouldn't swap them over because I'd driven home on them.....I'd be staying away from Superior at Aspley.....very bad service, and kinda rude!
Edited by QIK_GTR
Superior tyres is like walking onto the set of Fast and the Furious all the wanna be tough boys. I bought some chrome rims from them years ago they turned out to be fake, they were painted chrome rims they eventually started to peel.
What about Kieth for wheels on the southside.
Edited by subzeroR33
do people like the Tuna there?
I didnt want to swear in front of the kiddies, its school holiday time again... :P
got ya bud.
GO BACK TO SCHOOL KIDS.. u cant drive a GTR for the next 3 years at least so go back to boostcruising. ur not wanted here. hows that col?
Ummmm not what i had in mind!!!
But anyway, back to the topic at hand. I was driving past bob jane this morning and noticed they are having a sale with a free Ipod with any 4 tyres and rims...
Wanta Ipod???
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
