Im just about to dyno the car and i did a compression test
i got 190psi on all exept for for i got 187psi..
mind you i have only done 77km on the clock
Now some people say omg it should 150 psi
and other say it should be between 170 - 190
what area your thoughts ???????????????????
https://www.sau.com.au/forums/topic/195400-compression-test/
wet or dry test?
i think its sposed to be about 140-150 dry and and 160-170 wet but i could be wrong. im assuming you are referring to a rb25det.
you are lucky, i made a post yesterday about my 10 000km engine having 0psi in one of the cylinders...
wet or dry test?
yeah i have R33 GTS25T
Im about to have a heart attack i dont want my motor to blow.....
oooooo sorry to hear about ur cylinder
From what nearly every thread that questions like this have been asked, it more or less is irrelivent what the final number is (within reason) so long as each cylinder is pretty much the same within 4-5 points i believe.
Wellll how about this
Hills motorsoports said that it is should be about 150psi and 190 is far to much
Atm where my car is at Bel garage. they said 190 is high but excellent
factory compression in a RB25 is 172psi.
So if you have more you have a shaved head or decked block.
Either that or they put different pistons in when it was built.
But I have seen compression testers vary up to 30psi. My last one said I had 200psi in each cylinder. But they were all within 3 psi of each other so I didn't care.
Thanks for that mafia..............
The test on mine went 190 on everyone except for the forth wich was about 186-187.
how i just installed a gt35......... am i in trouble
What the guys said above is correct. Worry about variation between the cylinders rather than the actual number.
If you use a different comp tester, the results will be different again.
The actual number means squat (unless if it is reading ridiculous like 50 across all 6, which would most likely mean that the tester is f**ked, the person is an idiot and did it wrong, or the whole motor is f**ked)
Sounds like you have a healthy engine there , stock pressure should be around 170 psi (12.2kg cm2) on RB25 det @ 300rpm, warm engine ( normal operating temp) and WOT. If any of the above vary you will get different results.
If you use a thinner h/gasket , deck the block or cyl head the pressure will be higher , if you have carbon built up the pressure will be higher .
If you want to be sure on the condition why not do a leakdown test ??
Leak down test is used for when you have a low compression..................
what do mean deck the block????/ herd that alot lately but not understanding
You can have a perfect comp dude on all cyl with worn piston rings and or bore because the oil can take up the wear and hold perfect comp. If that was the case when you do a leakdown test you could have say 25% leakdown pressure loss). Now I'm not saying for one minute that this is the case with your donk, as I said before it seams its in good nick.
Deck the block/head= shaving a few thou" . Has the same effect as using a thinner head gasket..
Well the boys at bel my engine is in good nick and you should be happy it has a high compression
i just spent a crapload on my car dont wanna spend no more
btw..... why would someone shave the head on a Skyline
if the head is pitted, warped/not perfectly flat....You shave the head so it has a flat face for a new headgasket to seal. Generally when rebuilding a motor, you shave the head in which they only take off what they need inorder to get it flat, same with the block. Unless your building a wild motor with custom pistons/rods and you need to deck the block to achieve a desired CR and squish area.
A smaller area for the same air/fuel to be squeezed into results in a bigger/powerful bang equals more power...however it can also make it more prone to preignition.
whats the stock pressure for RB26dett?
also is carbon build up a bad thing?? or is it just the black smoke that comes out when the car is floored.
A little lower than RB25, 12.2kg cm2,
Carbon built up is not a good thing but it happens on most engines with age .
It usually gets blown out the tailpipe when you really floor that shit.
Carbon buildup is a funny thing, its not good, but half the time when you run an engine cleaner or whatever through the oil and fuel you tend to start burning oil and blowing blue smoke..
So sometimes the carbon buildup is a good thing as its sealing off its wear and tear from being old.
Id be shit scared to run any in the oil in my Hiace, 400,000km (that the speedo reads, :) its wayyy more) and piston slap when its really cold... dam if i cleaned the carbon out of that id probly burn more oil than i could put in it.
is carbon build up necessarily a tired engine?? rebuild soon?
this is from 130,000 kms 1997 R33 GTR with 175 compression im looking at
Edited by RodMonsta
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
