OK, atm my car is on minimal mods probably pumping about 180rwkw with heavy duty clutch but the problem is its slipping nicely
The car goes into the workshop in about 2 - 3 weeks to get a makeover and should be hitting the 250+ rwkw
So i need a clutch that can handle the power but still retain the drive ability as its my daily driver..
I was recommended an Exedy 5 Puk clutch but others tell me its worse than a Button clutch to drive
Anyone recommend what to get
need to order it sometime this week.
cheers in advance
https://www.sau.com.au/forums/topic/195453-time-for-a-new-clutch/
http://www.npcperformance.com.au/cgi-bin/m...main=nicsclutch
just put one of these in as my clutch was slipping to. grabs like a bitch, not to bad on feel although no where near as slippy as a standard (i bought modified nismo gtr pressure plate with 5 puck ceramic)
Edited by Pal
ive got an exedy cushion button + flywheel. its not as bad as it sounds mainly because its cushioned so you can slip it abit. pedal pressure is pretty heavy when first installed but after a while its almost feels the same as stock. maybe the left leg is conditioned to it now. engagement is great, may clunk a little at first in stop start conditions when your not used to how it engages. overall im happy with my buy. does what it does well.
Do a search for Jim Berry Raceclutch. Its all been covered before.
Wouldnt recommend Exedy from personal experience, useless imo.
If you dont machine the flywheel you wont get full contact and run the risk of slipping it in the early stages. For the extra $50 odd its well worth it.
The manufacturer doesnt always tell you but a clutch wont be covered under warranty unless the flywheel is machined.
don't even bother with the extreme. just got mine pulled out cause it was slipping and found that the clutch plate had worn away the pressure plate and flywheel and left the clutch plate in good condition. rand jim couple of weeks ago and for a heavy duty organic it will cost in the 850 mark, goes up from there. definitely get the flywheel machined.
Edited by Pal
the question you need to ask yourself is, are you willing to sacrifice a little bit of comfort for performance? It will be cheaper to get a twin plate cos it comes with a light flywheel and it will take the hammering. JB clutch is good (good feedback) abd NPC clutches. Now the thing is you have to take a look at the long temr costs of running and operation costs. JB wants A$800 for a single plate clutch rebuilt with a swap ove compared to NPC for under A$400. Now which one do you choose?
I did look into the clutch too. As im making 236.5kw@wheels. And the stage is a heavy car and i cant launch the car with the existing factory clutch. So i was looking at upgrading and took a look at JB and later i foind NPC which i think its a much cheaper option. BUT as im planning to make the car into the 320kw@wheels i started to dount the clutches (sinlge plate). So now i when out and buy the nismo twin plate ones. I havent received it yet but im confident that ie will be ok for a daily driven car. Just need pratising. Like i said before you can have comfort and performance. But if you are into performance go for the tinw plate. It will work out cheaper.
2c worth
Yudy
i run a nismo twin plate, drivers much better than my 9puk button clutch. takes abit to get uses to but the pedal isn't that heavy (near std feel) and it grabs like a s**t when you drop it :whistling:
plus nismo twin plates rebuild kits are only like $500
Edited by [Michael]
you should try and talk to people with the different setups you're thinking of getting and take the car for a drive. IMO brass/ceramic/puk clutch's are good for the track, but everyday driving will wear them out real quick, as mentioned above the disc is still in good condition but the flywheel and pressure plate wear out.
If the cars daily driven give it 9 - 12 months and you'll be having the box out paying more cash for a twin or something similar.
Cheers
I can vouch for the Exedy clutches.
I run with a GTR 4puk solid from Kudos and its unbelievably drivable. Its nicer than my old 9puk Xtreme clutch.
A mate has the GTST 3puk Exedy and that too feels awesome as mine does; apart from my heavier pedal they both have a smooth take up and can be driven normally extremely easy. Almost too easy as its definitely not a wise idea slipping ceramic clutch as they wear at an exponential rate.
Drive them correctly and u get good life. I got 70,000km's out of my old 9puk behind the rb30 and 100,000km's out of my original HD organic behind the rb20. The std nissan clutch shagged its self at 70,000km's.
Basically its a must to give a little distance and then lunge the car; try not to ride the clutch and once u get the hang of it driving a normal car and riding the clutch feels horrible. :P
Exedy GTR 4puk or the GTST 3puk FTW in my opinion. As I said, more drivable than my old 9puk Xtreme XHD. It feels much like a mates OS Giken twinplate. Nice smooth quick take up. The old 9puk used to shudder a little especially when reversing.
Honestly I was a little worried about the 4 and 3 puk within the exedy range but I really wouldn't be.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
