Item:
Volk GT-C 18x8 +36 18x9 +36 w/ 225/45R18 Yokohama DNA GP @ 80%
Website:
Item Condition: 9/10
Reason for Selling: Would prefer Gunmetal & 10" for rear.
Price and Payment Conditions: $3000 w/ tyres & lug nuts (lug nuts brand new), $2600 w/o tyres.
Extra Info:
Can supply brand new centrecaps (was going to keep them for the next set, but will buy another set if it means a sale) $200.
One rim has a small defect that I'm going to be having repaired this week. I thought I'd polish out a scratch not realising they had a clear coat and rubbed through the clearcoat with 1500 grit sandpaper. Can see my thread about it in the tech section. I'll be having them refinished (remachined & cleared) by depulu wheels on the gold coast. This will be costing me around $80. If you want to pick them up before I get the repair done take $100 off the asking price, and you can have them recleared yourself.
Apart from that, the rims are in otherwise excellent condition. There is no gutter rash at all. One of the 'volk racing' stickers is missing little bits and pieces.
Few initial pics, I'll get one of the volk racing sticker today.
Do not bother low balling me. I bought these rims around 9 months ago (fresh from japan) and still haven't got to use them as my car is currently off the road. I don't intend to lose alot of money on these and will keep them if I cant get my money back out of them.
Pictures:
Picture of the rim that I'll have refinished, or you can get refinished and pay $100 less. Depulu quoted me $78 to machine the surface (get rid of the old clear) and then reclear it. Turn around of around two days. I'll probably take this down to them monday unless someone says they want the rims as is, before then.
http://members.optusnet.com.au/qikmr2/lip3.jpg
Contact Details:
Email @ [email protected] or SMS 0439399598
Edited by -Totenkopf-
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/
Ah right! Price drop! 2800 inc. brand new centrecaps, lug nuts, tyres, the whole lot. The catch. One rim has one mismatched bolt. Wouldn't know if it wasn't pointed out, or you didn't look from inside the rim. Heads more or less the same, however, the nut on the back side is larger then the rest. Sent the rim away to Depulu Wheels on the Gold Coast to have one of the lips repolished. They returned it to me with the mismatched nut saying nothing about it. Called them today and they said that the original sheered when torquing it up, and they couldn't source one. Not only that, there is now a solitary scratch across one of the spokes, look like it may have been caused by a stanley knife or something, not very obvious (ie cant see it in pics or from more then a couple of metres away) however, it is there. Highly recommend anyone doesn't use Depulu for wheel repairs. The fact they try to hide damage they caused shits me off more then the damage itself as its quite minor.
Won't be using them again at any rate.
Will entertain near offers guys. Dogs gotten sick with mange or something so now I gotta foot the vet bill :( And my car is at least two months off of running, and I have another set of rims layin around anyway.
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3536827
I couldn't personally tell you. If your local to me your more then welcome to come test fit them though. If it helps, I ran 16" r33 rims on my car for a while. They fit like such - http://members.optusnet.com.au/qikmr2/mr2drags.jpg
I'll try find some info for you though, if your interested.
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3543735
From the registry on this site:
Skyline model = R33 GTST
wheel type= advan racing series 1 tri spoke
Wheel diameter = 17"
Wheel width = 8" front 9" Rear
Wheel offset = +35 Front +35 Rear
Tyre size = 235/45/17 Front 235/45/17 Rear
Modifications to fit: none
Basically exact same offset and width, so I assume these would be fine.
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3543788
I thought MR2 was front wheel? :S
Anyways coming to sydney any time soon? Thought id throw out a feeler.. As im keen but un-keen because your in woop woop from me.
Nope, mr2 is rear wheel drive, mid mounted engine (basically FWD style setup, but in the back). Unfortunately no to the Sydney. My gf has relatives in Orange NSW and she wanted to go there for christmas, however, she failed to tell me with enough time to make arrangements, ie, annual leave etc.
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3544217
GRRR... No good :whistling:
Ill save my pennys like we discussed and ill get back to you... If anyone has a R34 GTT and can confirm these will clear the brakes it would be great if you could help out either test fitting or confirming fit.
I like them :)
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3544223
GRRR... No good :happy:
I like them ;)
Hey mate,
I've been having a look around and I think the wheels will fit fine. There will also be no issues with brake clearance. These are a high disk offset and fit cars with large brembo's etc from the factory.
7.5 +40 is apparently the factory wheel size and offset. Going off this the front wheels will stick out 10mm more then the factory fronts & the rear wheels will stick out 19mm more then the factory rears. Usually there is alot of room between the factory guards and stock wheels.
Know someone going to Sydney boxing day who could probably deliver otherwise I could have them freighted.
Cheers,
James.
https://www.sau.com.au/forums/topic/195916-18-volk-gt-c/#findComment-3548034
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
