Im looking to buy a S2 33 in about 3 weeks and there are not many around in SA but quite a few in Sydney etc. I was just wondering whether someone can tell me whats involved in bringing one over in regards to taking it through Regency and what they look for and whether its worth the hassle. Also any help on some good places to get one locally would be appreciated there are not many in the trader or carslaes. thanks.
https://www.sau.com.au/forums/topic/196039-buying-interstate/
Its not hard to bring a stock example over, just a bit of cash, transfer or regos yada yada yada....
Modified, well some people have had good and bad results.... i got my 34 from Melbourne, didnt go through Regency, just the local cop shop for an engine check and bobs your uncle.....
As for local.... how much do you want to spend on one? do you want stock or basic mods (exhaust FMIC etc)
Good luck!
Good luck!
which cop shop did you goto?
does it need to be a specific one?
might go ask some questions cos im looking at buying from interstate if i cant find what i want here, and that would make it a whole lot easier.
I just called the Dept of Rego, told em i purchased a car from interstate, they directed me to download a form, go to the cop shop.... Elizabeth in this case, and get em to stamp the form after they have sighted and written the engine and vin number and take the form and your details and for me $1500 in cash to the rego office and BAM rego transferred to SA!
This was about 2 yrs ago tho!
That was for my R34, It was regoed in Vic... so $1500 got me transfer fees, stamp duty, 12 months rego in SA
Dont think it would have gone up that much, it all depends how much the car costs?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
