Hey I have a VL commodore and just threw out the old NA RB30 and transplanted a RB20DET into it, Ive just bought a T03G turbo can anyone tell me how good this will go on the RB20 I have, the motor is stock at the moment except for a TurboSmart supersonic BOV, I got the turbo from Japanese Motorsport and they said it will get me over 200kw?
https://www.sau.com.au/forums/topic/19611-rb20det-turbo-selection/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
