Hey Guys,
Selling my Sidchrome 1/2" Impact gun (Rattle gun) and my Sidchrome 3/4" Air ratchet along with my Impact socket sets, I believe they are Kinchrome, or a no name brand that kinchrome makes.
They were used for 2-3 months while I was doing my apprenticeship last year, and havn't been used since last December. They are in awesome condition as I always took extra special care of them and kept them well oiled when in use. I kept them as I planned on purchased a compressor but I just don't have the need for one.
I may have the case for the impact gun, but I don't have the one for the air ratchet or sockets, however they are in the plastic trays they came in.
SIDCHROME SA-600 1/2" IMPACT GUN
- 600ft/lb max torque
- Double hammer
- Rubber/plastic Case - Easy to clean, non slip
- Quietest Impact gun Sidchrome make
Clicky
SIDCHROME SA-RW38H 3/4" AIR RATCHET - Heavy duty
- 60ft/lb max torque
- most powerful air ratchet sidchrome make
Clicky
The Impact sockets range from 10mm-24mm off the top of my head, not 100% on that.
I have both regular and deep sockets which I will include.
So all up, I'm selling
1x SIDCHROME SA-600 Impact gun
1x SIDCHROME SA-RW38H Air ratchet
1x Set Impact sockets - 1/2"
1x Set Deep Impact sockets - 1/2"
1x Set Impact sockets - 3/4"
1x Set Deep Impact sockets - 3/4"
Asking $700 ONO for the lot, Happy to seperate.
Pm me or call/sms on 0402 198 170 - Bryan
pickup available from south melbourne, or postage at buyers expense.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
