hey guys, this is probably the billionth post like this...but i got this turbo, its only done a 1000km. I plan on bolting it to my rb25det in the meantime before the whole gt35r thing....
i need someone to tell me whats the deal with this turbo, good or bad, responsive or not...
all the info i have is its an rb25 rear housing with a machined wheel, a/r60 front cover t04???
part number on the core is 446179-5032 it says garrett.
here's a few pics.
thanks guys, appreciated..
also, if you guys did need wheel sizes etc...whats the deal? just get some verniers onto em?
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/196170-what-is-this-turbo/
Seems to be the 56T GT2871R. Should be pretty responsive!
Yes, that CHRA number = 56T GT2871 cartridge. With the larger (compared to 48T version) inducer size on the compressor, it should provide a responsive 240kW (maybe a bit more) on an RB25. Compared to the 48T version, it won't offer quite the same transient response (ie very close to stock-feel) but pretty good.
Any idea why your mate pulled it off the RB20, and/or what it drove like with that turbo fitted?
hey mate
I've just had a look at this turbo on my Garrett Master spreadsheet, and it appears as Simon-R32 said - a 56 trim GT2871. I know that the 48trim version makes 220rwkw at 15psi, just send a PM to Dale_FZ1 as he has one and has done extensive testing. I will certainly point him at this thread, as he'll be very interested to see your results.
I've driven his car and it makes a full 15psi by 2800rpm on the RB25. Very responsive.
This would probably make full boost by 3,000rpm (a little later due to the more agressive 56trim) and yeah, I estimate would make about 240rwkw and *maybe* 250rwkw if you squeeze her a little more. Depends on the exhaust housing though, as they are restrictive as hell and the RB25 housing on my GT3076 only managed 240rwkw due to it being too small.
But this is definately a f**ken fantastic upgrade for a RB25.
Edited by The Mafia
ah great news guys, cheers for your input, i got the turbo real cheap, its only done a 1000km so its still fresh..the pictures are bad i know but that actual rear wheel is as large as you can fit in that housing by the looks of how much its machined out...
my mate removed it off his rb20 due to the rings on number one going, he's currently forgie rebuilding it and wackin on a gt3540 off xr6t, not sure the rear they run i think .82 or something....but yea thats a different sorry.
The turbo on the 20 was a little laggy (rb20 nature anyway) came on strong at about 3700.
im about a week or so away from eventually fitting the gear so will have results soon for you guys.
anyone know if this core needs different fittings for oil, coolant etc..or will the standard rb25 lines suit? or is it just a matter of buying lines to suit gt2871r cores?
cheers for the info guys, really helpful, keep ya posted with results
  • 3 weeks later...
guys, wacked on this turbo over the weekend, running 7psi through stock tune with Power FC and already am i amazed at the responce, pickup and kick of torque.....such a smooth torque band even without a tune and on 7psi....Putting injectors, z32, fuelpump in very soon, will keep you posted.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
