  • Replies 41
Posted Images
would it be worth getting a powerfc without the controller?
yeah, the hand controller tends to be more of a visual aid then anything. Most tuners just plug in a laptop to tune the powerfc than use the handcontroller. Personally i would spend the extra 200 on the controller, but thats just me cause i like to fiddle with things haha.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3512210
the tuner said it's running rich and a few more psi would help that alot,i have a manual boost controller here would it be worth putting that on?
Edited by mjones
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3512216
thats abit scary... whos your tuner?
you'll notice an increase if you bump up the boost, and its probably the best bang for your buck mod you can do. Although thats not going to help with your afr, the ecu is already running rich and its going to continue overcompensating fuel, ie running rich. The only thing to help you with that is a piggyback like a safc, or a new ecu like powerfc.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513095
it's not my tuner it was just the guy at carline,which safc would u recomend?
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513174
how far are you wanting to go with you car?
how much power do you want?
what are you using it for?
this will determine what is going to be the best option as terms with cost efficiency for future modifications and your car running at its optimum level.
I remember, i started with a 121rwkw with an auto. Its now manual and will have 300rwkw when it goes on the dyno again.
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513216
see what i mean man, if u compare your graph to mine, s1.5 r33t, with fmic and exhaust.
U ARE DOING PRETTY WELL!!!
*P.S just to add a tag on here man. i have adjusted my fuel prs, now it runs crazily rich and on 8psi. so could i run 12-14psi well?, i used to hit a brick wall/flat spot at 12psi
Edited by r33cruiser
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513234
is that with the standard ecu?if it is how come it dips like that mate?
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513243
yer stock ecu
3" exhaust
monkey warehouse fmic kit
fpr
bosch 040
boost controller on 8psi
pod with shield
nfi why it does that hey. it was my first dyno on a dyno day.
but at time of dyno i had an 02 sensor that was on the way out, and plugs over 1yr old
i think that may be the reason
but changed that now
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513255
this would be my path i would take if you plan to have 200rwkw.
aftermarket ecu. Power fc are one of the most reputable ecus around.
some people have made it to 200rwkw on the standard turbo, but with being a bush bearing with ceramic wheel i wouldn't risk it.
limit on the standard turbo is about 12psi.
Also i would consider updating your injectors as they will get close to running on max duty cycle and also your air flow metre
Turbo- pretty much the best option and to retain standard manifold and not resorting to an externally wastegated turbo would be a GCG highflow turbo being ball bearing and having steel wheels, you can push the boost up to a greater limit then ya standard turbo and will easily hit 200rwkw.
GCG highflows are capable of seeing 260rwkw.
So my opinion if i was in your shoes i would look into
ECU
Split dump - less restriction
injectors
AFM
Highflow turbo
And then possibly blow off valve for better control and no leak.
there you will have 200rwkw and also and then some if you wanted.
Edited by bazr33
https://www.sau.com.au/forums/topic/196231-first-dyno-run/#findComment-3513292
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
