I know a guy who will shove his anus onto his BOV and give it some noise! lol
Then me might get the msg!
Damn stickers who do that! what area?
I live in Heritage Park and he said he living about 5 mins away from my place so I think he may in BROWNS PLAINS AREA
What race was he, you know aussie, asian etc?
Did you get a rego number?
Also just because he had a SAU sticker doesnt mean he is a member, he could of bought the car off a member. Any ex members that people know sold a Black R33 series1?
WO WO WO Slowdown...
Dont jump the gun here for a second.
You need to explain the full story not just a part of it, im sure no ones stupid to steal from you and drive their own car into you place of business.
Stop and think for a second, mabey there is a simple explaination for this. Mabey the car could also be stolen?
I notice from the way you posted your first language is not english. Mabey something you said or he said was mis-understood and that this could be a simple mistake.
My suggestion is let the Police take are of the matter, or if you want to try something on your own then PM me a image of the "alledged" theif and ill try and ID the user and contact them to help clear up the situation. Im certain there is more to this story.
Cheers Col
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
