Item:R32 RB25DE complete engine,loom,sensors and RB25DET short motor
Age:Late 93
Condition:Good to very good
Price:$800 ono for the lot priced for quick sale
To Fit: (What car)R32 or what ever RB30 conversion you like
Contact: Grant (please ring as I don't get on the computer much on 0428- 234- 732)
Comments:
This is a much sort after pakage as the motor will bolt straight in your
R32, loom computer everything.As most people have upgraded injectors and turbo already.
Just think rebuild this with forgies and chip your computer and you have a monster combo.
Or this head is great for a RB30 twin cam conversion as you don't have to worry about the VCT
[b]Bennefits with this pakage/engine[/b]
- Great for RB30 based engine build up ( cylinder head)
- Being you can chip your RB20 computer to accept this upgrade everything
else bolts on
- The cams have slightly bigger duration and lift
- Bigger throtlle body
- The block and internals are turbo spec (Bar pistons) just add forged pistons
I can assure you that the RB25DE Motor is in good conditon running order and originally an auto
non-turbo you know that it hasn't been trashed
The RB25DET short motor seems to be in good order as has no lip at the top of the cylinders and
you can still see the hone marks in the bore maybe grap the low compression pistons out of this
put in the other motor with fresh set of rings and bearings and of you go another cheap option.
Selling as a complete package WILL NOT SEPERATE
I will also throw in some heavy duty valve springs as well
I have no photos as everybody knows what they look like!
Please feel free to ask any questions you may have the best way is to contact me by phone
0428-234-732
ITEM SOLD
Cheers Happy Motoring
https://www.sau.com.au/forums/topic/196639-sold-sold-sold/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
