my rear main seal was leaking so i replaced it. now after a couple months it seems that it's leaking the slightest again. i can see oil buildup on the bottom of the gearbox.
what could be the cause of this. apart from the seal itself? my oil level seems to be fine, and i havn't got any other leaks. the new seal couldn't have shit itself already, but a few friends say the bursons seal i replaced it with it crap and i should have replaced it with genuine nissan seal.
opinions?
https://www.sau.com.au/forums/topic/196885-rear-main-seal/
It can be a couple of things poor quality seal I dout it as being so new (I only
use genuine parts now as much as possible) The engine may have a bit of blow by
eg gasses getting past the pistons or the engine breather can be blocked PCV
valve (Positive crank case ventilation valve) or the baffles in the rocker covers
may be full of sludge not allowing the PCV valve to work.Sometimes I have seen
marks on the crank where the rear main seals run normally I clean it up with a
bit of fine sand paper them with degreaser or something slimilar.You said the oil
level is fine which is good as if it is over full this can make the rear main leak.
Hope this is of some help happy motoring.
https://www.sau.com.au/forums/topic/196885-rear-main-seal/#findComment-3523467
Can only really be due to improper seal fitting. I recently got a new one from BSC, not fitted yet but im sure its going to be fine. Was only 15 bucks, nissan want about 100. Things to make sure are: you emeryed the crank surface the seal runs on to remove the groove. If its too deep from a hard seal then it will leak no matter what you do. Perhaps you could use a speedy sleeve if this is the case. Also check that your PCV valce isnt blocked and causing the sump to pressurise.
https://www.sau.com.au/forums/topic/196885-rear-main-seal/#findComment-3524607
New seals will also leak sometimes until they seat properly i.e. rocker gaskets etc. but thats probably far off. Dont over fill her either
Try what the guys said, soak your PCV valve in some thinners/degreaser and shake her until it moves freely. Should relieve any pressure off the seals
O/wise after preparing the gasket surface again, use plenty of gasket gooooooooooo
You could always put oil glue in there (stopleak crap) but then your just asking for trouble
https://www.sau.com.au/forums/topic/196885-rear-main-seal/#findComment-3526504
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
