Make: Nissan.
Model: 180sx
Milage: 140,000km
Transmission: Manual
Colour: Gunmetal grey
Complied? Yes
RWC supplied? No, car is wrecked.
Currently registered? No
Price: $2,600 neg!
Comments / Modifications:
Time to sell my 180 wreck.....
I will NOT be seperating any parts so please do not ask. Here are some more details....
- 1989 CA18DET 180sx.
- Gunmetal grey.
- About 140,000km's on the clock.
- 5spd manual.
- Has a lukey muffler/cat back.
- Pretty much stock car.
Now as for the damage....car was hit on the front driver side. This caused the driver strut tower to be pushed in, and the wheel was pushed into the drivers footwell (refer to pics).
The engine seems to be pushed over a cm or two. I havent had the engine running or anything after the accident, but after i was hit, the engine was still running (i had to turn it off). However, the throttle body got jammed open, and now the throttle body is stuck.
I will take some better pics on sunday when i got to my dads place. This wreck would be ideal for an import wreckers or something like that, as im NOT going to be stripping any parts off it, so please dont ask, wreck is being sold complete! This 180 was extremley clean before the accident, never had one mechanical issue with it in the year i owned it, and it took me 7 months to find such a clean example!
Any other questions, just ask.
Located in SE suburbs of Melb.
Not sure what price to put on it, but for the time im going to say $3,000 neg. NOW $2,600 neg
Thanks,
Will.
https://www.sau.com.au/forums/topic/197074-180sx-wreck-for-sale-ca18det/
  • 4 months later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
