Need Someone To Help Me Complete Vehicle Modification Application
hey all
sorta another yellow sticker thread..
went to the pits today, managed go get an extension to the 24th of Jan, which im happy about ;)
but i go that extension because i need to complete the vehicle modification application.
so im gonna need someone who knows alot about this or a profesional to help me complete it.
because it takes sooo long to go through the system i need to get it all right so it wont get rejected.
can anyone help me or recomend me somebody?
thanks
luke
What are you trying to get permitted?
mainly engine mods, rebuilt motor with high mani + turbo etc...
suspension mods too like camber and caster kits, sway bars, rear cradle bushes.
some brake mods too.
also whats the rules about half cages because no one there seemed to know? :domokun:
Welcome to the club mate! Firstly, be thankful for a 6 week sticker because all I ever got was 3 weeks until I went to O'Connor. Guy there gave me a month but even that's not long enough because of how long it takes.....
PM me & if I can help you out I will, but this will get you started:
http://www.infrastructure.gov.au/roads/saf...n/vsb_ncop.aspx
That's what all mods must comply with now, I'm sure something in there will refer to cages, possibly under body modifcations. With the turbo & maybe other things you surely will have you will need to get an engineering certificate in regards to it's fitment & suitability. If anything can help you out, get that done to hand in with your application & you should be able to get it through sooner.
So far I've applied...been rejected. (3 weeks) Applied again...accepted for pre-approval (4 weeks). Now I'm up to the engineering stage, but then when the papers are done & handed in, I wouldn't expect any sooner than 4 weeks, and due to the time of year it could even be like 6 or so if people are away on holidays/leave etc etc... Got this sticker about the 20th of August, I'm looking at about 5-6 months or so :domokun:
Inspector at O'Connor wasn't impressed saying "you've had over 3 months to get it done!!". "Well, only got pre-approval about a week or two ago so how am I meant to know what you guys want?"
as long as whatever you do is legal/engineered, etc you wont have a drama, but the idea is to get pre-approval, especially for things that may be borderline.
Mates 120Y with fj20det passed , only thing they were worried about was chopped firewall .. engineers cert sorted that n it licensed .. 800kilo car with 240hp :ermm:
While were on the subject of yellow stickers, what are they like if you have cut the reinforcing to fit front bar/intercooler? Im guessing they make you go get some constructed or...?
Can someone please let me know...
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
