haha you need abit of humour when your day is going like shit...
anyway im guessing the z32 afm is shagged aswell, is there any resistance test or anthing to test the actual afm?
so another update:
I have a spare q45 afm, which i thought i would try. I hooked it up and the afm volts started to read as they should around the .2-.4volts when the engine was off but in the igntion postion. It was around 1v at idle, although it ran very rough (i had it on the vh41 setting for airflow)
I then stuck the stock r33 airflow meter and took it for a drive. The volt reading was simular to the q45, and the car reved as it should and there was no spultering or anything like that throughout the rev range. But it hunts at idle now... 700-1400rpm just goes up down up down.
So i now am concerned about 2 things,
1. why is it hunting?
2. why didnt it like my q45 afm even though i had it on the right afm setting?
I'll try and get some pics of it, the owner has done a decent job at making it look good, now it just needs to go properly haha
thanks again
Edited by R34GTFOUR
as for the hunting side of things, i have reset the powerfc and gave it 30mins to "relearn" its idle, but it didnt work
I kinda knew it wont stop hunting the second i started it up with the reset ecu, it hunted straight away. When we first put a powerfc in my bros car, it never hunted at idle, it just ran really rich until it learnt the idle then it was all good.
BUT... (and there is always a but haha)
if i took timing out from the powerfc (about7-8degrees so its at about 8degrees BTC) then it stops hunting and idles at 950 but its not a normal idle. It kinda sounds liek its struggling even though the rpm doesnt change. If i return the timing to 15 BTC it starts hunting again.
so yeah... still thinking...
Edited by R34GTFOUR
check the physical loom connector to the PFC
as you have been messing around with wires and swapping ECUs check the actual plug is connecting properly
most common causes of crap running with the PFC and wierd idle etc is the actual harness isnt connected or is a bit loose
tighten the bolt a little too to make sure its straight and even and a firm snug fit. you should do the self idle learn, once the ECU is stable
it sounds like the stock AFM and q45 AFM you have are both OK its just you have some wierd idle problem - see above
yeah i'll have a closer look at that tomorrow, although the plug looks fine and i always tighten the bolt to secure it all the way (i even press the outside edges of the plug cause the plug doesnt always go in evenly).
The actual harness itself hasnt really been molested too much, 99% of its be untouched. The only thing thats been "tapped" into is the main power (3pinouts), eccs relay was made up, water temp and tacho feeds to the dash, and the starter signal from the igntion barrel, and all these things check out as good.
I'm starting to feel sorry for the owner cause everything that shouldnt go wrong, has. I mean the odds that his q45 tps, z32 afm and a brand new power ALL being broken are almost statistically impossible but they are haha, i was intitially expecting one thing to be wrong lol
Everything besides the stable idle is working fine. The car revs fine, and powers beautifully right to limiter, no surging and spluttering, it just hunts.
Anyway i'm given up for the night, its only got a front pipe as an exhaust so its bloody loud and i dont want to get noise complaints, i'll wake them up first thing in the morning with it haha.
So tomorrow:
-Im taking my bros powerfc (the owners original powerfc is broken) out and putting it back in his skiz to make sure everything still works as it should (even though i just deleted his tune lol)
-I'm going to let the skiz run then record all the sensor signal voltages, then put the powerfc back into the hq ute and compare the signals, hopefully something jumps out at me.
-If not, im going to go pinout to pinout and record each and every value and compare that to the workshop manual and see what it says.
-If still no joy, i will purchase some fuel and some matches and burn the bastard down to the ground....
once again thanks, your input has helped me alot :D
PROBLEM SOLVED :/
Okay so there was 4 main areas from stopping the rb25 from running properly:
1.
The powerfc was faulty, it didnt give out a tps voltage, I stuck my bros powerfc in it and it works fine. Hopefully he can get his fixed under warrenty
2.
He wired in the z32 afm plug so i just doubled checked the wiring. He was using a diagram that listed the wiring code as 1,2,3,4,5 (5wire plug), going from left to right, but the actual plug has the numbers 1-5 but 1 starts on the far right hand side. What this means is that he wired the signal and voltage back to front (SATO GTS, you were spot on haha). I re-wired it and it works fine now :D
3.
The tps that he had on the q45 wasnt actually a tps, but a throttle switch. The switch was either on or off, there was no variable to it. I stuck my q45 tps, which was the proper tps and problem solved.
4.
Now this last problem got me stumped for a while, and this is what was causing the hunting at idle. On the q45 throttle body it has its own idle up. It uses a coolant line going though it to warm up this valve, and once it hits operating temperature it pushes the throttle back to fully closed. Since we arent running any coolant to it, the throttle was open too much at idle so it was getting to much air and confusing the ecu making it hunt.
I pulled the whole assembly off the throttle body and adjusted the idle screw and it now sits dead on 800rpm, no hunting.
So after a LONG weekend, a car that barely started and hardly ran now starts first go, idles smoothly, and if the diff ratio wasnt so tall would be pretty quick, but it still revs freely and cleanly. Its going to get tuned and the boost upto 12psi and it should go alright for a hq ute.
Thanks again for everyone that replied, especially paul, it helped me alot.
Cheers :(
Edited by R34GTFOUR
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
