the GFB Stealth-fx does what you want.......................
Apparently it doesn't... as it's only 50 50 plumb back... if I plumb it all back then same thing as stock.
Thanks.
It does
I bought one for CHEAP a few months ago, its on my auto mod'd stagea atm.
stnd bov got "repaired" :D
and now that Im on holidays, as of like 1hr ago, Im going to take off the FULLY ADJUSTABLE gfb stealth-fx bov (worth $550 new)
and put back my fixed stnd one
my mack truck is about stealth not sound
contact me if you want it for what I paid for it
I used it on full plumb back and full spring tension, works real nice and sounds, well, funny.
a few test runs would sort out what sort of atmo / pmub back percentage mix works on your car
its not my kinda thing, I got it to hold boost pressure, but Im going about that little quest a different way now so I have no need for this as of next week.
but if you are into bov's, then the GFB stealth fx is worth a research matey
  • Replies 149
It does
I guess, I'll just leave it on Stock then... I can't be bothered, BOV's are so expensive, and the sound that I want is really hard to find... some, e.g. WRX BOV's sounds like a pigeon on steroids... sounds so ghey... I guess, I'll leave it stock... who cares....
Cheers,
you all need to attach a duck call whistle to the end of your blow job valves.
it will solve everything.
ssss quaaawawawawawawa
I gues there's nothing we can do then... Heard you can modify the stock on to make it sound better, but apparently not a good option... never mind... thanks.
god there are some dumbshits on here
ok here i go
stock r33 bov which is NOT PLUMBED back so its running into the atmosphere ok
car runs on map sensor and i dont have all the stock plumbed back piping shit so i ran it atmosphere
bov leaks like a heap of shit,must i explain myself any fkn further or are u just another keyboard warrior wanker on here who pays every other c**t to do shit on there car?
thanx good day
lol well your the dumbshit who is running a plumb back BOV to atmo?
If you had half a clue you'd know the stock plumb back setup returns air into the intake pipe to keep the idle stable when dropping from various RPM.
And you'd also know it circulates air through the plumb back setup to keep gear changes smooth while driving (prevent surging).
Now it does leak air through, but because its plumbed back it all goes back through to the same place in the end.
Link below also shows the fact that the stock BOV DOES leak, is you make it ATMO it will leak into no where.. = loss of boost = loss of power
http://www.skylinesaustralia.com/forums/St...l=stock+r33+bov
So if you don't plumb it back, of couse it will leak idiot thats why its plumbed back in the first place..
Now which moron reroutes a plumb back BOV to ATMO?
Your the dumbshit who has hooked it up wrong, now you blame the quality of the stock BOV saying its shit and doesn't work?
Basically there is nothing worng with the BOV, just your stupid setup.
If you had hooked it up right it would run perfect but because you have hooked it up like a retard it clearly doesnt work.
AND I wasn't having a go at you, all i was saying is that what you stated was incorrect.
The stock BOV will leak when not plumbed back because thats how its designed to work.
Your the one who got abusive :)
Edited by abu
I think CEF11E was runnnig like 19psi on stock R32 BOV with no leaks and this dumbass reckons his is leaking.
Probably not even running close to 19psi either.
THE MAFIA is always saying he is running 20psi with a GT3076 making 300rwkw on a stock BOV with no leaks..
Are you making more than 300rwkw buddy? You must be if your BOV is leaking that bad!
Keyboard warrior your self wanker.
Edited by abu
i was running 1.3 bar thru the stock bov you f**kin wanker... both atmo and plumbed back and either way it fkn leaked. dont try and tell me whats right and what wrong i KNOW what it does and i KNOW how it works im stating what it was doing and ill stand by it. dont need someone like u to tell me otherwise lol
What Abu said is correct, I done some research and have spoken to a few people at Chaser Motorworks - the way a R33's BOV works is based on a setup that the BOV is plumbed back into the intake pipe as the engine expect this - without this setup (e.g. atmospheric blowoff) then this will muck up all mixtures and settings hence stalling...
I have to say, I love the Pphsshhttt sound, but if it means non-stop stalling, I'd rather not have the sound so that my car rounds smoothly... but I agree... the stock BOV works perfectly and does its job - don't fix what aint broke... I mean, I'd love to have the ppsshhhttt sound if it's full plumb back but don't know if there's such a BOV that works this way....
Guess getting both the sound and preventing stalling is impossible
Thanks fellas...
Also, what's the difference between a Stock R33 BOV and the following?
Which would host boost better?
Which would make better sound and would both be as good?
Cheers,
http://cgi.ebay.com.au/SKYLINE-R32-R33-R34...1QQcmdZViewItem
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
