Item: Garret T04Z 800HP Ball Bearing Turbocharger (Ex Housing : 0.70 A/R. T4 Split Pulse) 0.70A/R Comp Cover
Condition: BRAND NEW, never used
Price: $1900 or nearest offer. I paid $2300 for it originally with ported shroud option
To Fit: (What car) Any car
Contact: Reply here or VIA Private Message
Comments: Brand New with ported shroud comp cover (looks like bullet holes). No longer need it for my car. Perfect for high power GTR or GTS-T/GT-T
Edited by Blue_GTR
https://www.sau.com.au/forums/topic/197803-garrett-t04z/
hi mate is this a full kit, can u put some pic up.
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3536394
hey mate i been told to get a gt35r, how would this turbo compare to that? i might be very interested, when dose this spool and hit full boost? how much power do they usualy make on a 34gtt at the wheels ? will i need internals ?
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539107
This turbo is pretty much one size larger/step up from the GT35 in the Garrett Catalogue.. On an R34 GTT, you would definitely want internals and cams done to get the most out of it. These turbos need to run 18-20psi+ boost to get in their efficiency zone where they really start making good power. You would probably hit full boost by 4,500-4,900 RPM. And then hit redline very very quickly
In my opinion it would make over 350kw atw very easily with supporting mods. I know of GTR's making 400awkw with this turbo. If your sticking with standard internals, i wouldnt go larger than a Garrett GT3037/GT3076. They will easily make 250-290kw atw with standard engine GTT, depending on supporting mods.
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539152
ive got a r32 gtr with standard internals, ive got like the turbo back exhaust, the apexi pwc, adjustable greddy cams and a really good boost controller, also got a trust fmic 300+600+100mm with the hks pods, i always wantesd to ask someone, will i be able to run a t04z turbo kit with a standard bottom end and what psi will ui be able to run it at because some people say you can never run a t04z turbo on a standard gtr bottom end, but please let me know,
cheers tony
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539258
i got prity much same setup on my r34 gtt with a few more things but not cams. and iv been told that i can get the gt35r with a good tune and expect 360hpatw which is what i shouldnt try to go over with standard internals n bottom end..
but im wondering if this will be an option to dump this big boy on insted for almost the same price.. :)
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539402
cheers tony
Tony,
With the supporting mods you have it would be fine, do you have greddy cams and adjustable gears or just adjustable gears? I would suggest cams or at least your standard cams dialled in to get most of the larger turbo. I know of R32 GTR's running between 300-350kw at the rears with T04z, 260's cams and standard bottom end. Also running 11sec1/4s on Pumpfuel. Expect full boost around 4,500-5k and it will take off like a jet from there. I probably wouldnt run more than 19-20psi on the standard bottom end, and with a good tune.
Keep in mind to change to single turbo you will also need the following:
*Turbo Manifold to suit single T04Z turbo (6Boost are around $1,000, HKS are $1500+ or Ebay for under $450)
*External Wastegate -44mm or larger, id personally go a 60mmV-Band (HKS $1000, or Ebay $250ish)
*New dump/front pipe and screamer/wastegate pipe (Would have to be custom)
*Bigger injectors, Walbro 255LPH intank Fuel Pump
*New intake pipe and airfilter setup to suit single turbo
*New/modified intercooler piping from turbo to intercooler
*Larger AFM's if not running MAP sensor type ECU
And last of all, dyno tuning. Would still be cheaper than buying a full HKS kit etc, if you buy the right parts to match it.
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539652
Tony,
bro i swear 2 god because you told me that i copy and pasted all the information u wrote to me and im going to go single to4z asap bro, thanks for that mait, ur a bloody legend, cheers mate
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539708
Haha.. No worries. Turbo is still for sale :)
https://www.sau.com.au/forums/topic/197803-garrett-t04z/#findComment-3539733
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
