Oils - Engine, Gearbox, Which Ones And Where To Get?
Hi all,
Went down to autobahn today to pick up some Redline shockproof, but it seems they don't sell it anymore.
Where can I get some in Adelaide? Northern suburbs preferred if possible.
Cheers.
Edited by Ionos
  • Replies 59
dont use redline in your gear box its not good for jap gear boxs ask michael at auto barn mile end and mark tillbrook as the components in the oil isnt good and can cause alot of damage!!
Well, all reports I've heard are that it can work wonders on a worn gearbox. I've got a bad crunch going into 5th gear. I also used it in my last skylines with no dramas, but open to hearing alternatives short of a gearbox recondition.
Hey Kel, nice to meet you the other night...........do you know what these guys recommend for a GTR engine and driveline and if so, any chance of putting bit of a list together, I should be dropping all the oils cos who knows when they were done....I've only had the car for 4 weeks.
Hey guys, I know you probably already have your favourite brands of engine oils (generally Synthetic) but has anyone considered ULX-110 which has all the advantages of Synthetic without losing the advantages of Mineral based oils. A guy that I worked with at Adelaide Engine Service for many years is the National Distributor for the oil which is now used by many Top Fuelers around the world including my mate Marco Elbe who runs a 6 sec Keith Black '57 Chev that you may have seen at the Extreme Horsepower Show...if you knew what Marco has spent on that engine you know he wouldn't use a mineral based oil unless it was fully tested and proven.....here's an extract from their website;
http://www.ulx110.com/
Performance Advantages: Our multi-grade oils for gas and special fuels such as top fuel and alcohol have been designed with the help of some of the top engine builders in the United States. Demulsifiers and anti-scuff agents have been added for extended protection. Dyno tests have consistently shown an increase in horsepower consistent with synthetic oils but with none of the bad side effects such as scuffed cylinders and piston skirts, detonation, and weak spark due to wet plugs. Better oil pressure during severe and continuous service applications along with a reduction in oil temperature of 20F or more is also a plus. Our 2 friction modifiers work together to coat internal engine parts which results in protection at start up, and reduction of internal friction by 38%. This results in reduced fuel consumption of 8% or more in most vehicles.
Like I said, I'm good mates with the National Distributor and would be happy to approach him for a group buy if the interest was there....ULX-110 may even help the well known problem with RB engines where too much oil hangs around upstairs causing alot of blow-by.
i have redline in my 31, running 25 box, has made the box feel alot better since going to it, been in there for a few months now, cops a thrashing once a month and no dramas yet.
I have also heard this theory too of it being bad but thought i would try for myself and my mechanics said it is a good oil and the amount of hours they have put into that car i doubt they would wanna put anything bad in it.
Oh and where to get it - fours n more can get the stuff in, would probly be cheaper through motor traders though.
Edited by skylineguy19
Hi gang,
Changed the thread topic since I got my answer, and some good discussion going on.
RB25DET gearbox takes 2.8L - more will go in but will cause problems. Some people fill it to the brim, that is not correct! You wouldn't fill your engine with oil to the brim would you?
http://www.skylinesaustralia.com/forums/Ch...+oil&st=20#
Cheers.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
