Hey guys/girls,
This my be a stupid qustion but can i potentially do any damage to my car if I drive with the silencer in the exhaust?
The car is tuned at 381rwhp @ 18psi and I'm running a Blitz Nur SpecR exhaust which is pretty loud.
Running poncams also which makes it a bit lumpy and even louder again - pretty much instant yellow sticker job if I pull up next to a cop car.
So although it drives like an excel with the silencer in, if I am just putting around not driving at all fast can anything go wrong?
Obviously i would take it out when wanting to drive it hard, but I'm just concerned I might damage something by restricting the flow so much.
Cheers,
Tay
Edited by taynewguy
https://www.sau.com.au/forums/topic/197836-driving-with-silencer-in-exhaust/
I remeber a magazine article were they were testing a high flow cat, car had been tuned for the high flow cat, so they decided to see the diff the original cat made.
Stock cat ended up being a massive restriction causing detonation etc(high rpm end). so I see your new silencer as causing similar effects IMHO.
Ok cool, thanks for the heads up guys. I just put it on yesterday to see how much it would quieten it down and went for a sunday drive.
Didn't really give it a hard time but didn't see any excessive knocking either way.
Found out pretty quickly that it's no fun, deadly slow and with absolutely no accelleration.
Anyway, that drive didn't last long. Quickly went home ripped it off and went for a real blast up in the hills.
All smiles again :banana:
Edited by taynewguy
I got one of those.. keep it in the boot actually, it's got me off a yellow sticker before for my exhaust being too loud :laugh: I just said it'd loosened and come out and I needed a screwdriver to get it back in ;)
Driving with it thou is boring, and sounds like crap!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
