hi guys,
my brains being doing some fothat thinking stuff over the l;ast few days (wife is now complaining of a burning smell in house)
i know that an intercooler on a turbo car serves a perpose inthat it cools the air charge that has been heated by the compression of the turbo....
BUT...
would a small intercooler on an NA be beneficial? as the colder the air inthe more power we get potentially. but eventually there would come a point where the restriction in air flow negates any benefits in cooling the air charge? so where might this occur? is it just pointless puting an intercooler on or would it actually do something?
thoughts and suggestions please.... not sure if this is a stupid idea or not......and no one over this side of the pond to ask ....
https://www.sau.com.au/forums/topic/197926-intercooler-theory/
an intercooler on a NA will make it lose power, as the temp it would cool it to is the same as it was when it entered, although if you had the cooler as a front mount it would actually soak in a touch of heat from the radiator while you are sitting in traffic so it could heat the air up.
basically all it would do is add restriction.
the reason they work on a turbo car is that the act of compressing air heats it up, plus the heat radiationg through the turbo heats it up a bit too. so the air coming out of the turbo is up close to 100 degrees at times.
yeah it would restrict the flow as the air have further to travel (Depending on intercooler set up) if anything on an N/A possibly heat wrap the induction pipe? stop it heating up from surrounding systems in the engine bay. just my 2 bobs..
hame
Yeah only good for forced induction, If you also built a ramflow or fan to draw the air through the system it would be a benefit, but that kind of setup would still work better without the ic restricting flow.
Fresh air will always be cooler than anything that goes through an ic. Unless ofcourse it's a dry ice setup obviously.
Edited by madbung
look in the sticky of how to get power out on an N/A there is good info in there, let go of the idea about running an intercooler on a n/a it a good thought but there is better mods out there for you hesh!
IT WILL SLOW UR CARR MAN, lol i tried it at the drags one time as i turboed my na but before i did i mounted the intercooler as trial fit then i was going to heathcote so i figured y not, and yeh i lost a sec and a half on time slips with it on, wont help any, done and dusted
cheers guys i guess thats a definitive no then1lol
i was kinda leaning that way but like i say you ask a question like that over here and ya get "why dont you have a turbo ....etc etc ..." so thanks again . the Intercooler idea has left the building.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
